C63 AMG (W204) 2008 - 2015
Charcoal filter delete. NOT SO HAPPY
Old Sep 20, 2011 | 05:30 PM
jacob502's Avatar
2008 C63 ,2009 SL 63 AMG, 2011 SLS AMG
Originally Posted by JeffDL
I'm just laughing because his posts are all the same arrogant bs. "I KNOW" "I'M THE EXPERT" blah blah blah. Isn't there an SL forum?
Never actually said that, but thanks for admitting. I'm also pretty sure there is a stupidity forum somewhere that suits you
Old Sep 20, 2011 | 05:31 PM
jacob502's Avatar
Originally Posted by bushburninc63
i agree with you on this statement.
you can join him too
Old Sep 20, 2011 | 06:11 PM
Sincity's Avatar
Originally Posted by xtyper
I tend to agree with this, as I think it was already proven through the Propain vs JonsC3 runs where the only difference between the cars was the K&N filters/charcoal deletes. Propain's car with the K&N filters & charcoal deletes clearly had more top end.
Propain also has the "TTM Box Top Mod" where Bruce grinded out the flat funnel portion to replicate the flow of a "ROW" box top.
Vadim did a dyno a few years back that showed a slight increase from removing the charcoals and that is why we do it. As for your butt feeling it.....doubt it.
Old Jan 4, 2012 | 06:31 PM
ergon's Avatar
C63
I just got my ecu back from Kleemann so I figured I'd change out the K&N's for AFE's and took out the charcoal. Now I've got a check engine light after about hour or two of driving. Got in it a couple times. Light came on coming back home. Does the ecu just need to get used to the new set up or do I have a problem?
Old Jan 5, 2012 | 10:56 AM
Mort's Avatar
Make sure your box tops are fastened down properly and your filters fitted correctly. The big thing to check is for air leaks downstream from the MAFs so make sure that the rubber Y fittings are properly fitted to the box tops (no buckles or folds) and clamped snugly with no air leaks/gaps.
Old Mar 24, 2012 | 10:03 PM
6.2AMG's Avatar
2011 E63, 2008 ML63
i got my 11' e63 dyno'd today...before and after including the CD and the major difference was a pretty big dip within the 4000-4500 rpm range...has anyone else experienced that?
Old Mar 24, 2012 | 11:15 PM
  #32
bhamg's Avatar
C63 AMG
Originally Posted by ZephyrAMG
The charcoal is to remove certian emissions and contaminants, and it does NOT cause more than 1-2% air restriction.
Not giving you a hard time but just curious...is this number the result of an actual flow test or is it just guesswork?
Old Mar 25, 2012 | 10:54 AM
  #33
jim07's Avatar
09 c63 p30 mars red
I have tried removing my Carbon filters three times. Every time after a few hours of driving I get a CEL. I now run K&Ns with the carbon. I think some cars/ years are more prone to have the CEL when you remove them.
Old Mar 25, 2012 | 11:32 AM
  #34
vessproms's Avatar
C63
i dont think you can feel the difference
Old Mar 25, 2012 | 04:56 PM
  #35
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Yes you have a problem without charcoals. Well in my experience without the charcoals the damn CEL kept coming on even when driven mildly. I tried this many times without them. The damn ECU NEVER adapted. So I put them back on. The light stayed away.
Old Mar 25, 2012 | 04:59 PM
  #36
I think its the P30 c63. Since we both have them.
Old Mar 25, 2012 | 09:32 PM
  #37
jim07's Avatar
09 c63 p30 mars red
Maybe just '09s?
Old Mar 26, 2012 | 02:36 PM
  #38
Weistec's Avatar
Former Vendor of MBWorld
Weistec
Hi Guys,
There isn't a year cut off where some cars get CEL for charcoal delete and some don't, but there is a variation in different software versions that make some cars prone to triggering a CEL while others can make many intake changes and never see a CEL. It seems Mercedes purposefully lowered a parameter that will trigger a CEL if charcoals are removed to desuade intake modifications.
Our tune adresses this problem for those of you experiencing this. Obviously with a supercharger strapped to a car we ran into this problem early in our development stages so it was easy to apply the fix to NA cars with charcoals removed as well.
This is just one of the many proprietary things we've discovered on the ME9.7 ECU to enhance customer satisfaction.
-Weistec
Old Mar 26, 2012 | 02:51 PM
  #39
Even Money's Avatar
'15 VW GTI
Good info. Seeing as you've done a lot of testing on this issue, can you lay to rest whether or not charcoal removal adds hp or torque?
Old Mar 26, 2012 | 02:59 PM
  #40
Weistec's Avatar
Weistec
The result from our testing is in line with what others have claimed. We've seen a 3-8 wheel hp increase, the larger numbers coming from cars with other modifications and the lower numbers coming from standard vehicles.
-Weistec
Old Mar 26, 2012 | 03:00 PM
  #41
cptdaz's Avatar
home the point
No CEL with charcoal delete here.
Old Mar 26, 2012 | 03:53 PM
  #42
Even Money's Avatar
'15 VW GTI
-Weistec
Thanks! What do you guys recommend for an air filter?
Old Mar 26, 2012 | 06:27 PM
  #43
I hate you.
Old Mar 26, 2012 | 06:38 PM
  #44
propain's Avatar
See Sig
I hate you.
Deleted the charcoals at 500 miles. 14,000 later no CEL.
You got the CEL back after taking them out the last time?
Old Mar 26, 2012 | 07:21 PM
  #45
Yes. I drove it for couple days. Kept coming on and turned them off with scanner. I wanted to punch the dashboard. BTW I made mends with Bruce. Saw him at Mexico. I need a updated tune.
Old Mar 26, 2012 | 10:25 PM
  #46
propain's Avatar
See Sig
That sucks. Maybe re-flash your tune and try again. I would let the light stay on a few more days. It might go away on its own as the ECU adapts.
Good to hear you fixed your relationship with Bruce. He is really not a hard guy to get along with.
I was thinking on heading down this Sunday. Ill look for you. We need better MB turn out.
Old Mar 27, 2012 | 01:22 AM
  #47
c63insd's Avatar
C63
I have an 09 P30 and I just removed my carbon filters this weekend. Within 2 days (about 100 miles and 3 or 4 starts) of driving I got a CEL.
Not too concerned because I am getting a tune this weekend which will get rid of the CEL!
Old Mar 27, 2012 | 02:05 AM
  #48
sighting's Avatar
e63s edition 1
I bought a set of CF air boxes for my car, I had them installed for about 2 weeks before I noticed that the stock air boxes I had was actually ROW models. I guess they came with the brabus kit. Which in interesting as its not mentioned in the kit. Luckily i sold it for exactly what I payed for them, thank g** as i (and my gtech ) could not feel a difference between them and ROW ones. After following up with someone from brabus they mentioned that the ROW's should be good for (2hp / almost a rounding error on a standard dyno) but +-10hp at 100mph on the road
Old Mar 27, 2012 | 09:49 AM
  #49
cptdaz's Avatar
home the point
I hate you.
I notified my tuner of the change before getting ecu flashed. Maybe you just need to reinstall another tune?
Old Mar 27, 2012 | 10:37 AM
  #50
propain's Avatar
See Sig
I was thinking about this Jon. When you remove your charcoals are you still running OEM filters? Maybe try upgrading to the K&N's and see if the better flow helps.
