WTH..... "limp Mode"!!!!!
Could replacing the ECU be a solution?
Sorry you are having that issue. I feel for you because I would be really angry having to make payments on a car that right now cannot be driven and fixed.
Please keep us updated. The dealer should hopefully find a fix soon.
The negative of all this is that it is probably out of your own pocket for all the repairs and the dealer will flag the car as being modded and future warranty is voided (let's not get in a side discussion whether this is right or not)
Are you running the Evo sport pulley?
Where is your source for this claim that each car has a one of kind factory tune?
I highly doubt this.
Again - this is just what I've gathered from various threads here on the forum during my research as to whether I was going to have a tune done, and could just be speculation - I am not certain that it's fact. Perhaps someone other can either deny or confirm this belief that's more familiar with ECU/Warranty issues.
Just get a tune and quit worrying about it. My dealership knows I have the secondary ECU. But what can they prove?? I bought it, never got it tuned, had second thoughts...
I have had the car in there for several warranty issues related to the engine and not a word from them.
car runs perfectly i only noticed it happen when i went on the track and pushed the car and drove it hard.
The c63 will only go limp mode in sport or manual mode, this is due to the auto-blipping function. I haven't experience limp mode in C mode before, always in sport or manual, especially when blipping down.
So what u need to do is to change to the new pedal, which gives more accurate reading, that is what i was told.
Like some people, even after changing the new pedal, the limp mode happens.
Next you need to reset your car adaptation back to zero, factory setting. Because of the old pedal, the adaptation data is messed up and likely to be out of range, so even with new pedal and readings, crap still happens.
After setting back to factory adaptation, the car will learn your driving pattern from scratch again.
BTW, mine is custom tuned, so i think the limp mode has nothing to do with the tuning. My throttle is now set to open even bigger with the new pedal, so any error will cause the car to go limp mode even easier. so far no problem for me.
i hope this helps people out there still with this problem.
