C63 AMG (W204) 2008 - 2015
Bank 1 lean and bank2 lean
Old 11-04-2011, 03:00 PM
kidjnco23's Avatar
09 white c63 amg
yea they do but i thought ut was just the gaskets that were a common problem it was actually cracked on both sides!
Old 11-04-2011, 03:19 PM
Sincity's Avatar
Originally Posted by Merc63
Common problem. Glad its fixed. I believe they use different bolts now.
Common problem that they crack or common problem that the bolts are loose?
Old 11-04-2011, 03:39 PM
Merc63's Avatar
C63 AMG
I dont know if the problem is the gasket or the bolts. But my tech told me they used different bolts when they fixed mine so I assume its a problem with the bolts and not the gasket itself.. That is unless they changed the gasket design or material and he never mentioned it or was unaware of it.
Old 11-04-2011, 04:09 PM
kidjnco23's Avatar
09 white c63 amg
Beats me but they replaced the whole intake manifold!
Old 08-11-2014, 09:47 PM
Heath T's Avatar
C63 AMG
My car has been giving me this code for a while now. I had it in to get it fixed. They replaced a valve on a canister for fuel tank fumes. Still the code came back.
I have the car there now and they found a leak on the intake manifold gasket, its a known problem with the M156, there is a SB for it. I talked to another member which had the same problem, they changed his intake gasket and used new bolts, he hasn't seen the CEL since.
The techs sprayed some brake cleaner around the intake gasket and got a rough idle at one spot, indicating a weak seal.
Its nothing major, its more to do with emissions, the ECU is really sensitive to these issues I am told.
They told you they sprayed HIGHLY flammable and paint damaging brake cleaner all over your engine while it was running? They sound smart.
You are supposed to use water.
Old 08-11-2014, 11:45 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
holy man, that thing is a US$3500 piece! don't ask me how I know...
Quick Reply: Bank 1 lean and bank2 lean
