Costco gas
I don't benefit either way. I haven't advertised for any particular brand of gasoline. I just want the group to be aware that there IS a difference in quality between the majors and the 'others'. As I said, if you're not keeping your car for long, save your money and buy cheaper gas, because valve deposits won't have time to build up and affect performance. For me, I'd rather spend a few extra bucks a year so that my car will run better, longer.
Costco's gas?
Sam's Club Gas?
Kroger Gas?
Meijer's Gas?
BJ's Gas?
Being that you work in the industry directly, can you find this information out? This would really help us all in making more informed decisions when purchasing gas from these chains. I also think this thread should be posted not just in the C63 area, but in the main area as well to inform all that drive MB's AMG or NA.
Personally, I use a mix of Kroger, QuikTrip (I see they are top tier), Sam's Club gas.
Since 1995, all gasoline sold in the U.S. must include an EPA-approved detergent additive. All Costco gas has always contained these additives. Costco gas stations are well maintained and our fuel has always been 100% guaranteed.
Increasing Federal emissions and mileage requirements, plus the competitive pressures of the automotive marketplace, have led to improved and more complicated engine designs. These improvements make many engines more sensitive to carbon deposits on intake valves and clogged fuel injectors. Dirty engines can sometimes trigger a "check engine" dashboard warning light. Many of the latest model vehicles perform better using fuel that contains more than the minimum EPA detergent requirement.
As our valued member, you expect Costco to always offer the finest quality products at the best possible price. Gasoline is no exception. Costco has closely studied fuel additives and engine deposits, and conducted extensive fuel tests at nationally-recognized laboratories. As a result, we decided to increase the detergent additives in our fuel to provide a better value to our members. Cleaner engines run better, run longer, and they pollute less.
Costco gas with Kirkland Signature Clean Power detergent additives contains five times the EPA detergent requirement. Clean Power doesn't just keep your engine clean - it also helps remove any existing deposits. Costco Gasoline - Something good just got better!
Look for the notice above each pump as we add Kirkland Signature Clean Power detergent additive to the fuel at all our gas stations.
And this from Top Tier's home page:
Since the minimum additive performance standards were first established by EPA in 1995, most gasoline marketers have actually reduced the concentration level of detergent additive in their gasoline by up to 50%. As a result, the ability of a vehicle to maintain stringent Tier 2 emission standards have been hampered, leading to engine deposits which can have a big impact on in-use emissions and driver satisfaction.
- I have no proof that Costco's additives are of 'lesser' quality. My only point is that they are not Top Tier, and from a few posts on this thread, Top Tier fuel seems to be an important purchase criteria for forum members. From the excerpt from Costco's site, it appears as if they are using their own proprietary additive package. However good or bad that add pack may be, its not Top Tier. Top Tier requirements are not simply based on additive/detergent levels, but on test results.
- Where Costco buys their gas is virtually irrelevant as that supplier is not including their own add pack. Again, from the previous post it appears Costco adds their own. It is the quality of this add pack that matters - not what Costco's supplier may use in another product.
- I don't know who supplies all of the retailers you've listed. Chasing that down is not something I'm interested in doing. Many supply agreements are regional - based on the suppliers regional refining & supply capacities. So many of the retailers will buy from Major A in Region 1, but Major B in Region 2, etc.
- We'll never know the details of the add packs of various retailers. These are closely guarded secrets.
- Top Tier is a higher-quality standard set by the automotive industry, not the fuel industry. It can serve as a good indication of who/what is high quality gasoline when trying to decide where to buy. Trying to determine fuel quality is very difficult for an individual to do. Top Tier certification can make this task a little simpler by relying on third-party standards.
I don't see how that wouldn't clean up any mess that Costco gas has created. That is IF, Costco gas is not Top Tier.
I'm going to fill up tomorrow and have a chat with the attendant to get some more insight...
