C63 AMG (W204) 2008 - 2015
Looking for wheel spacers, and questions.
Old Nov 22, 2011 | 05:13 PM
stangxs's Avatar
c63, 11 e350 (DD)
Looking to get spacers for my wheels, 10mm for rear, and what do people usually run in the fronts on stock wheels?
Where's a good place to order from, and would i need new lug bolts?
Thanks!
Old Nov 22, 2011 | 05:26 PM
_AMG_'s Avatar
C63
10mm is good for the rear don't know how much other people are running in the front.
You can contact Evosport, ACGSD, or RPM North for the spacers and lugs.
Old Nov 22, 2011 | 05:28 PM
gthal's Avatar
2012 C63 coupe
The only problem with spacers is that they are an absolute B&TCH to remove... even if you use anti-seize they can be near impossible to get off the hub. I used spacers on my M3 for a while and then decided it just was not worth the headache and bought wheels with better offsets. If you use spacers, prep the hubs VERY well and use a little anti-seize paste on the hub lip only... otherwise, forget about ever getting them off the car
Old Nov 22, 2011 | 05:29 PM
stangxs's Avatar
c63, 11 e350 (DD)
Originally Posted by _AMG_
10mm is good for the rear don't know how much how much people are running in the front.
Old Nov 22, 2011 | 05:38 PM
GHAZAN's Avatar
MBUSA
Do you need longer bolts for 5mm spacers or 10mm+?
Old Nov 22, 2011 | 05:39 PM
BK63amg's Avatar
'16 GTS Solar
You will need extended bolts. I am running 8MM in front and 12MM in rear on stock wheels. They sit perfectly flush.
Old Nov 22, 2011 | 05:55 PM
Rsquad911's Avatar
97 Porsche GT2 Wide Bodied Cabrio, Mercedes G500
5mm should be ok with stock wheels and lugs.
Make sure you get 5 full turns before torquing the lugs.
Old Nov 22, 2011 | 09:09 PM
bhamg's Avatar
C63 AMG
I have used 5mm spacers twice in BMWs and got four turns with the OE lug bolts. I definitely recommend getting the appropriate length lug bolt equal to the spacer width...look and see for yourself how little four turns is on a lug bolt and think if you'll feel safe doing that. FWIW I used 10mm spacers on my M Coupe and like gthal states, they are not coming off easily, if at all, even after using anti-sieze as well as a Dremel to polish everything prior to installation. If you're planning on switching between OE and aftermarket wheels I wouldn't bother trying spacers.
Old Nov 23, 2011 | 12:42 PM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
Let me know what you need we have all sizes in stock along with longer bolts... i will also be in HB starting tonight until Saturday for turkey day.
Old Nov 23, 2011 | 06:41 PM
stangxs's Avatar
c63, 11 e350 (DD)
Sweet! Do I order them from your website? Couldn't find them on there.
Old Nov 23, 2011 | 06:49 PM
James@ACG's Avatar
Just give me a call
858-633-1018
James@ACG
Old Dec 20, 2011 | 11:34 AM
E55 Bulldog's Avatar
2012 C63 Black Series, 2003 Hummer H1 KSC2, 2003 Hummer H1 HMCO, 1997 Hummer H1 HMC4, 1969 Jaguar E
Im thinking about doing the same thing with the stock 18s to get them flush. What is the price on a set of spacers and bolts?
Old Dec 20, 2011 | 03:36 PM
FiveKai's Avatar
2011 C63
i did 12mm in the front looks good. with the hr springs
Old Dec 20, 2011 | 09:33 PM
James@ACG's Avatar
spacers are $95 for the pair in 10mm, 12mm, or 15mm...
extended bolts are $3/ea for standard, and $6 for black
Old Dec 20, 2011 | 09:37 PM
izzyAMG's Avatar
2019 GLC63, 2020 M2 Comp, 96 Miata M Edition & 19 Forester
Do you have other pics that shows the flushness of your ride?
Old Dec 30, 2011 | 09:41 PM
mvagusta's Avatar
bmw e-60 550i,bmw e-92 m3, c63coupe p31, stable of Italian stallions MV's
So 12 rear and 8 front. Is your car lowered? What size tires are you running? It looks good..
