Need some help removing the second resonator
2010 c63
Hi, I have a LT MHP headers with mid pipe and akrapovic exhaust system.
Looking to remove the stoke second resonator do I need to to X pipe and if not what's gonna happen? and with witch company should I go?![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
thank you
thank you
Since the MHP mids are already straight piped you might wanna consider going with an X pipe. Personally I would get straight pipes in place of the resonators, or an H pipe.
No company sells just a resonator delete kit, so it would have to be a custom job.
Mine are straight piped with the MBH 2ndary cat delete X pipe and it sounds great imo.
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
You do not 'need' an xpipe. Simply go to an exhaust shop and he will cut out the second resonators and replace with a straight piece of pipe. Be prepared for a very loud exhaust which you may very well find tiresome over time and perhaps some drone. Alternatively you could replace resonators with an xpipe which any good exhaust shop should have sitting in the shelf. The xpipe will reduce the noise level a little bit and theoretically should yield and small increase in low down torque.
2010 c63
Delete the resonators and replace them with straight pipes.
It will be loud with the Akrapovic mufflers but not as loud as the OEM mufflers.
