Oil Consumption Question
Im interested to see what comes out of this and how MB handles this.. AND if replacing these parts is going to ultimately be the answer to your oil consumption. Thanks
http://www.brushresearch.com/cylinder_hones.php
Here's a picture of a fresh hone. This creates a good surface for the rings to wear into:
Hopefully everything works out for you...
Thanks for the updates, keep them coming.
There would be some down time getting the block state side, but that would be the proper fix for this IMO. I wouldn't settle for anything less.
I am no mechanic or engine builder. But I did work in a local engine shop years back tearing down engines for rebuild and the only time we didn't re-hone the cylinders was when the engine was barely ran. IE, it would be put in, fire up and within a few days or a week spin a bearing so the engine would get sent back to us.. This was very rare, but it did happen occasionally.
The cylinder bores themselves are also unique. The M156 is world's first production engine to feature cylinder bores with twin-wire-arc-spray (TWAS) coating. TWAS is a new process that creates a very low friction surface, which is twice as hard as conventional steel. The application involves using water at high pressure to roughen the cylinder walls. Afterwards, high voltage is run through two metal wires, which begin to melt. An atomized gas is then used to spray the metal particles from the meted wires on to the cylinder walls. Afterwards, the cylinders are honed.
Porsche's are worse than us.
But 1.5 qts is a bit much, I think. Both my C63 and E63 use about 1/2 - 3/4 qt between oil changes, so I'm very fortunate. I just added 1/2 qt to my C63 last week, and I'm due for a oil service in 1700 miles. There would be some down time getting the block state side, but that would be the proper fix for this IMO. I wouldn't settle for anything less.
Drive the **** out of it when you get it back. If it doesn't burn oil, trade it in once the warranty is up. Get a new one.
Or if the problem persists, demand a short block. Then I'd be comfortable keeping it.
Funny. My pops bought a brand new GMC truck years back. He made them put 2 new crate engines in it.. 1st because it was knocking bad, piston slap. Second time, they change the oil and got antifreeze into the oil somehow so they put another engine in it.. No pissing around from GM on these issues... You'd think a company with the $$ and rep like MB would just throw you a short block and get it over with.
I am beginning to think that the uppers in MB don't give a **** about their rep anymore from the things I hear on here and my own experience with them...
Have you tried calling MB USA head offices, etc. I'd be raising a **** storm. Get advice from local engine shops on the issue. Explain to them that your re-sale value on this car just went to complete **** so MB can save themselves a few dollars and just throw in new pistons, etc, instead of fixing it properly and issuing you a short block.
Thanks!
Cheers, Pickles.
Whatever is left is definitely not going to assist in seating the new rings, but makes things worst.
Thanks!
What exactly are MBs standards in a case like this? What is taken into account to determine the block is fine?
These are questions I'd have for the SA.
Current standard for porsche is 1.6L in 1000KM, or 1 quart per 350 or so miles.
Its absolutely ridiculous.
Some DFI 911 engines burn quite a bit of oil and others don't, but with porsche's ridiculously high allowable oil burnoff, nothing gets done about it.
AS for the air cooled cars, a car that burns much more than 1 quart per 700 miles or so is likely in need of new valve guides.
