C63 AMG (W204) 2008 - 2015
Common Problems with the C63 AMG
Old 12-08-2011, 03:15 PM
SonnyakaPig's Avatar
MB
I got to say, it really seems hit or miss with the build quality of these cars. Some people have great, trouble-free cars, and honestly, I'm happy for those that get to enjoy such a special car with little-to-no problems.
I think this car is special because the engine is awesome and the car looks very nice.
Old 12-08-2011, 04:09 PM
KINGPIN 007's Avatar
2010 c63
Im at 10k and these are the only minor problems that I have had:
1. broken fog lights (i think many people have experienced this one)
2. squeaking noise when sunroof is open
3. My oil sensor that reads what my oil level is at went bad and had to be replaced
Other than that, awesome car
Old 12-08-2011, 04:18 PM
blownS's Avatar
'12 CTS-V
Originally Posted by CELLryuu
i have a coupe, and yes they fold down but the driver would have the steering wheel in his chest cause the seat was so far up. so you can do it on the passenger side and they would fit. but, if you have a passenger, they would be smashed up against the dash.
infiniti was able to do it on a smaller car?????
Well, look at it this way: at least u get to the golf course faster.
Old 12-08-2011, 04:28 PM
khmergod's Avatar
2011 P31 C63 2015 CLA45
5k miles atm. Starting squeaking about 4k miles. Can't find the cause and it only sometimes does it. Usually after driving it for about 10 mins after a start. Other than that, rock solid. Oh, the only gripe is the turn signal. Very sensitive. Sometimes when changing lanes and not just turning, I go to turn off the signal and I accidently signal the other, makes me feel like an idiot.
Old 12-08-2011, 05:58 PM
Jean Valjean's Avatar
1997 Ferrari F355 Berlinetta, 2014 Mercedes Benz ML 350, 2008 MB C63 AMG (deceased), 2009 MB C63 AMG
Tires seem to melt at an alarming rate. (:
Old 12-08-2011, 11:54 PM
c63addix's Avatar
2011 C63 Calcite White
My car has 4400 km in it only, but a sign popped up today saying Service in 30 days. Could it be oil change already!?
Old 12-09-2011, 09:46 AM
  #32
Mort's Avatar
15000km or 1 year for service A. Oil & filter change and inspection. Time to change the oil already!
Old 12-11-2011, 02:17 PM
  #33
Doenermann's Avatar
2009 C63 AMG
... Rattle around Nav screen driving me insane. Seems to go away when cover is pushed on with force, dealer says it's "normal". Anyone have / had this?
On that squaeking passenger seat, I just had my driver's seat adjuster replaced under warranty. Used to make a noise when moving in it / cushion was pushed down.
Steering sqeak was recently fixed by a new hose, still some noise present.
Old 12-11-2011, 04:39 PM
  #34
JimmyR's Avatar
E63S
I get a vibration - not really a rattle - when the Sat Nav screen is in the up position and driving on coarse gravel roads. It is almost certainly coming from the cover to the Sat Nav, almost as if it is one of the hinges under it vibrating. Better when the dash has been in the sun so is warm. Haven't raised it with the dealer, is pretty minor really and I dont often drive with the Sat Nav screen raised up
Old 12-11-2011, 05:04 PM
  #35
Pit-Pony's Avatar
2015 C63S E1 (sold 2012 C63 AMG Sedan (Premium & APX)) & 09 C300 Sport 4Matic
If you have limited slip diff (performance package in Canada), than you are due for an diff oil change.
Old 12-11-2011, 06:17 PM
  #36
Doenermann's Avatar
2009 C63 AMG
Haven't gotten to experience a warm dash yet and won't for a while However my noise is exactly the same with the screen up or down, but I agree it is the cover, only for me it doesn't matter what position it is in. Dealer seems to be willing to fix it if I tell them what to do, Techs just don't want to spend time finding the issue in fear they find nothing and don't get paid.
Was a little hesitant to purchase the car due to the pending suit, but I figured if it's not just isolated cases, hopefully we'll all get at least some good will once warranty is up.
Old 12-11-2011, 06:51 PM
  #37
derek's Avatar
A couple of fast cars.
+1. Lol. thanks for having the courage to say it
Old 12-11-2011, 09:51 PM
  #38
C63newdude's Avatar
C63 AMG
Originally Posted by blownS
1) Ticking noise from the motor due possibly to faulty cams (wouldn't say it's "common", but prevalent enough that there's a class action lawsuit ongoing);
2) Oil consumption/burning (many threads on this);
3) Inadequately sized rear tires; and
4) Foul odor from A/C (easy dealer fix).
These are the ones that have directly affected me. There may be more that I'm unaware of.
The odor has to do with two main things:
Cabin air filter and recirculating seting on the A/C unit. Don't recirculate the air, instead just push the other button(the one that allows air from the outside).
My car use to stink a lot until the last last service when I replaced the cabin filter and I started using the A/C non recirculating mode. My .2c
Old 12-11-2011, 09:53 PM
  #39
C63newdude's Avatar
C63 AMG
My concerns would be the oil comsuption but I was told that this engine consumes oil. I am not too worry, I put a quarter every 5 or 6 thousand miles. The other common issue would be the tires getting worn out fast and some smal rattles from the cluster.
Old 12-12-2011, 04:25 AM
  #40
dkhm3's Avatar
2015 M3 2016 X5M 2008 C63 (sold)
I'm adding these two problem links to this thread
https://mbworld.org/forums/c63-amg-w...ed-s-mode.html
https://mbworld.org/forums/c63-amg-w...tely-dead.html
Old 12-12-2011, 01:49 PM
  #41
MB
I think the oil consumption gets less as the engine ages. And it shouldn't be too much of a concern because the car will tell you when it's low.
Old 12-12-2011, 09:25 PM
  #42
j bro's Avatar
2009 C63 ///Amg
rear fender flares arent wide enough!
Old 12-13-2011, 12:23 AM
  #43
RL1
RL1's Avatar
AMG C63 Affalterbach Edition
the last few days the "check coolant level" warning comes on at cold startup but disappears after a minute of warmup...i did have the coolant level checked right away (the first time) and it seemed to be normal.
for those of you having smell issues, i recommend Chemical Guys Stripper Scent...it's awesome!
Old 12-13-2011, 02:11 AM
  #44
LFM_Vancouver's Avatar
C63s now in the garage. Sold-GLA45 AMG Edition 1, Sold-2010 Mercedes C63
25,000 KM on my 2010
1-high pressure steering pump hose needed replacement (they ended up replacing the entire steering rack)
2-replaced both driver and passager side mirrors (they made awful noise when folding in)
Both under warranty and have had no issues since. My dealer is very nice and always takes very good care of me.
Old 12-13-2011, 02:58 AM
  #45
DuaneC63's Avatar
AMG GLC63. Audi R8
Gas, tires, oil, tickets, gas, tires, oil, tickets, repeat if necessary.
Old 12-13-2011, 11:05 AM
  #46
coladin's Avatar
2014 C63 507, 2012 R350
Squeeling brakes, had rears changed afetr 1k, still there, the fronts at 6500km and now all is quiet, I am at 10k now. Rattling from Sat/Nav that goes away when nav is down. So it stays down.
Other than that, considering how stiff the springs are in this car, the rattles/squeaks are not an issue which means that the cars are well built.
Old 12-13-2011, 11:27 AM
  #47
jafores's Avatar
08 C63, 07 ML63, 92 500E, 70 300SEL 6.3, 63 220 SEB Conv. Sold 02 G500, 97 E50,92 C280,71 280SE 4.5
Originally Posted by Merc63
Intake manifold gasket leak.
Noisey cam chain adjusters.
Both fixed under warranty
What are the symptoms of the intake manifold gasket leak?
Old 12-13-2011, 12:16 PM
  #48
Mort's Avatar
I think you will experience a rough idle (rougher than normal) and CEL. Never experienced it myself - knock on wood!
Old 12-13-2011, 02:29 PM
  #49
sighting's Avatar
e63s edition 1
GPS, GPS oh, did i mention the GPS.
The dam car has been in 4 times now for the GPS./
And they have actually replace it with a brand new $4k (on the invoice) unit from MBGermany. still the dam thing does not switch on. Shows i am a submarine in the ocean. or is muted.
Old 12-13-2011, 02:35 PM
  #50
-=Hot|Ice=-'s Avatar
Cars.
Well at least you get a new Nav unit.
Quick Reply: Common Problems with the C63 AMG
