Should I get ROW airboxes?
Did we ever get a dyno read on if there are any power gains?
Is that pretty much the only diff is the charcoal filter delete? Couldn't I just remove the filter and pull out the black plastic that the filter mounts to?
#32
From the pictures that I have seen, it appears that if you want to make your own ROW box, all you have to do is pull out the charcoals and dremel out the lattice that holds it in and remove some of the plastics that impedes airflow. I'm pretty sure that's what ppl are doing for their airbox mod.
#33
2014 Audi RS7
Okay guys, let me be a little more specific. Look at the "horn" where the air enters. The stock horn is flat on top because of the charcoal filter and much shorter and the ROW is nice and oval and has a much larger entry area. I can't explain it better then that. Here's a close up of the ROW.
![Should I get ROW airboxes?-e167e1a2.jpg](https://mbworld.org/forums/attachments/c63-amg-w204/380115d1542321600t-should-i-get-row-airboxes-e167e1a2.jpg)
Now, go back up and look at the FLAT stock entry "horn".
#34
Now, go back up and look at the FLAT stock entry "horn".![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Would that change make that much of a difference in the way the car sounds and runs?
#36
Can you just cut that out as well to open up that airway?
#38
2014 Audi RS7
There is a significant difference in the actual size of the opening of the ROW "horn" vs. stock and NO you cannot modify or cut the horn at all. Thats a precisely measured and metered hole that the MAFS are in.
Synjn (12-17-2021)
#42
Just picked up a set from James at ACG. Sounds a bit louder. Perhap some HP gains but I bought them because I like the stock look. I'm sure after a flash and some exhaust work they would yeild a bit more power.
#46
Received 2,836 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Comeon man, seriously? The thread is over 4yrs old.
The following 2 users liked this post by BLKROKT:
roadkillrob (12-30-2016),
Slow_c63 (12-29-2016)
#47
They keep coming and coming.....LOL
titans99 try OE Discount parts. The part #s are around if you search.
https://www.oediscountparts.com/part...?siteid=215242
#50
Must be something to do with the new resident evil game everyone is talkin about
