Question about turning/horsepower
Hello again folks,
I am just curious to know one thing, if a C63 is tuned to produce more horsepower, that technically means, you're telling the engine to work say extra 20% to 30%...
Wouldn't that make the engine less deplete faster than an engine that's consuming only it's standard?
Or, since this is the same engine that's used on most AMGs but with different tune, we know it'll not harm the engine long term?
Please explain that part for me. Thank you!
AMG engines HP are detuned and limited from the factory. It's really much more capable than its advertised HP. It's a marketing thing. So when you ask a 3rd party "tuner" to tune the c63. They are unleashing your engines true potential. But there has to be balance between engine and chassis. At its current state the c63's stock HP is already over powering the car. If I decide to tune the c63 I would improve 1) tires 2) add LSD then 3) the suspension and chassis regidity.
+1
Thanks for the compliment but you really dont know what an LSD is? aka limited slip differential. Tuners use different type of braces attached to different points of the cars chassis to lessen flex and body roll. It makes the car more planted to the ground thus create more grip. I honestly dont mind giving you more info but these are things you can learn on the net with a little bit of research. I'm going back to sleep now.
izzyAMG, you hit the nail on the head. Everyone wants more HP out of there C63, that's all you ever hear on these forums. But they don't take into account the chassis and tires have a significant role in the handling of more HP. You can't have one without the other, that is why the M3 out performs the C63 on the track. The beast under the bonnet overwhelms the chassis, and it rolls over it tires in the corners.
thanks for clearing things up for me guys.
i feel so ignorant.
i tried looking on youtube, but does anyone know of a video that can show exactly how turning works? like what needs to be modified. i learn better when i see things as opposed to reading about them
i feel so ignorant.
follow up question:
if the engine is detuned, that means, technically, tuning back the engine should not lead to a faster deprecation of it since it is expected to function for x amount of years under the 540horsepower tune for example?
Well... I understand your "technical" reasoning. but I think that can be said more as a theory. Yes the engine is dituned and is more capable of HP than what it had from factory. Which in theory is expected to last a good amount of years or else tuners will not do it if they think all engines they tune will start smoking the next day. But engine reliability cannot be determined by HP alone. For example how you maintain and use your car. You have to take note that AMG is very conservative. They give us a lot of margin for error because they know we are not all car engineers. When you add the performance package for example, they also replace engine components. Whatever reason they do that, Marketing, to help increase HP and reliability, etc. Or all of the above. So in short... your expected life of an engine is base on many factors not just it's HP capability.
These are terrific engines and they have terrific tolerances!
LSD Lysergic acid diethylamide if you were around in the sixties, but if you remember what it was that means you really weren't there.
