MHP Carbon Ceramic Rotors & Pads Arrived!!!
I have Evosport rotors. I'm just not using them right now. Kinda scared of this happening to my set.
I got about 30,000 miles out of a set of stock rotors.
Carbon Ceramics are the next level, designed to take lots of track abuse without fading and I imagine would last a VERY long time for street only driving.
You could have got way more out of your stock rotors, unless you're tracking the car?
Did you measure them with a caliper? They are good for 3mm of wear (front).
So both your stock and evosport rotors looked like those pics after some heavy track days?
Are you saying the RB slotted are superior so far?
!bottom Line this is the best brakes i ever used better than Evo rotors better than OEM .
Talk to Andy i think he is doing group buy for them !
I saw a M5 at Roebling completely wipe out at the end of the straight (somehow it didn't roll). Damage actually wasn't too bad - new bumper cover, new wheel, new tires, new caliper, and perhaps some bent suspension pieces. All caused by an drilled after-market rotor that broke.
I have some slotted only rotors from EVOsport (not installed yet). The rotors are lighter than OEM because they have much less material. Less material in the rotor means that drilled rotors will be more prone to cracking. I think I am comfortable with the OEM drilled rotors, but not the EVOSport drilled rotors - at least for track-driven cars - drilling AND less material in the rotor makes me nervous.
I am interested in how long the carbon brakes will last. Some early Porsche applications had very poor wear on track, which was the opposite of what was expected. I think a change in the pad compound eliminated this. The price might be justified (if we also consider the performance improvements) if the carbon pads and rotors last significantly longer.
Tempting.
What kind of discount?
Just Received MHP New Carbon Ceramic Rotors & Pads (front only) .
I just toke one picture of them tomorrow will be installed and i will test them !
Sorry for the Iphone picture
Forget to mention that MHP may be doing a group purchase to get whatever price breaks they can for interested customers .
