C63 VIN Decode
Can you help me with a VIN on my buddy's 2012 E63 wagon? He bought it used from another friend and unsure of his delivery date. Helluva car btw. Got me thinking.
Thank you sir!
VIN WDDHH7EB0CA637098
Thank you sir!
Looking at this vehicle to purchase and need a datacard. Thank you!
2012 C63 Sedan. VIN WDDGF7HB1CA687120
Thank you!
WDDGF77X99F236395
Thank you!
Datacard attached.
Regards,
Joe
Datacard attached.
Regards,
Joe
WDDGF77X99F236395
Datacard attached.
Regards,
Joe
Thank you sir!
Datacard attached.
Regards,
Joe
VIN:
WDDGJ7HB2CF876442
Thanks!
VIN:
WDDGJ7HB2CF876442
Thanks!
Datacard attached.
Regards,
Joe
Looking at purchasing this 2010 C63 tomorrow and was hoping you could provide the data card.
WDDGF7HB8AF373125
Thank You in Advance!
WDDGF7HB8AF373125
Datacard attached. I'm assuming you are aware of the head bolt issue on these engines. This one is in the affected group.
Regards,
Joe
Looking at purchasing this 2013 C63 tomorrow and was hoping you could provide the data card as well.
WDDGF7HB9DA796877
WDDGF7HB9DA796877
Datacard attached.
Regards,
Joe
Much appreciated.
My doubt is, please check here: https://mbworld.org/forums/c63-amg-w...ion-sorry.html
Basically, people from AMG (that work in Affalterbach) and AMG dealers keep telling me that a P30 code car has always the OEM differential, even if does not appear discriminated at the built sheet as 471. Only the fact that the code P30 appears already states that the car has the "AMG automatic 40% rear locking differential" (which is not an LSD "per se", it's an "automatic locking differential" that will only engage when slip is detected and does not activates while the car is neutral, only with ESP off and with the gear clutches engaged will the "AMG locking differential" ever activate under certain specific conditions).
