What the hell is wrong with my wipers?
I put them on low, rain sensing and they work just fine. But invariably I'll come off a light and they'll go nuts and start wiping to beat the band. They are on the turbo setting and the only thing that slows them down is turning them off and back on again.
WHat do I need to do?
George
Same thing happened with my X3. Sometimes it would just go nuts even though it was barely raining. Went straight to the dealership and they fixed it within minutes.
Head back to the dealership, they should fix the issue.
I have had 3 M-Bs with the rain sensing wipers - each year they are better than the last, so you can imagine how crappy my '04's wipers were.
The only thing that I have found that helps this is to keep the windshield absolutely spotless and the wiper blades should be regularly cleaned / wiped down. Even a very light layer of crud or dirt (even just a little rubber from the wipers after an hour or so of using them) seems to confuse the sensor into thinking the windshield is wet.
i use the orange rain x windshield wiper fluid... helps me use the wipers a lot less often... so i just keep them off unless i really need them... sometimes even in heavy rain i don't need the wipers... and the wipers will also last longer since you're using them less
are you leaving them on when its not raining? Because they are not designed to be. Turn on and leave alone when raining, then turn off when rain stops. The sun hitting the sensor at the right angle can fool the sensor.
2018 AMG GTR, 2017 GLS63, 2019 C63s
Nope. I RTFM and saw that they should only be on in the rain.
Well, i understand the cause of it, but if you think how to reset it is self explanatory than you are a smarter man than I and I wish you'd share. I have had several cars with rain sensing wipers and none have done this.
Haha...I guess I have always just lived with it. Our 2005 C was terrible for uncontrolled high speed wiping but our 2008 R was much more controlled and better behaved and my C63 has given me very little problem. On either it seems it would not stop wiping at high speed once it started but I did wait it out a couple of times and eventually the speed reduced and things settled down. I used to put the wipers on slow continuous wiping to get the speed back under control and then back to intermittent if it was not heavy enough to warrant continuous operation. I suppose you could turn the wipers off for a few seconds and then back to intermittent to achieve the same results but that may impair visibility. I have also had them go straight back to high speed wiping and thus left them on slow continuous wiping for a while to keep things under control. I also give the windshield a shot or two of windshield washer to try to clean any dirt that may be on the windshield off and to break down any oils that may be smearing on the surface of the glass. I think the windshield may be getting a film build up on it in the dry with tar and oil from the road and this may be smearing around when the windshield gets damp. It will take a while for this oil smear to be washed off and that may confuse the rain sensor into thinking the rain is heavier than it actually is on the lower part of the windshield. A couple of times it seemed that the wipers went on to high speed operation while on intermittent setting when I gave the car a fair amount of throttle position. But that may have just been coincidence rather than a controlling parameter for intermittent wiper operation. If you do leave the wipers on intermittent all the time (my wife does) they will come on for no reason at the oddest times to remind you. Also bug guts and bird splat do a good job of confusing the rain sensor as well. A few times I had to get out and clean the dirt off the sensor to get it to operate in a reasonable manner. In the mean time slow continuous operation or off returns sanity to the day.
I turn off and then on as a remedy, or just let it spaz out for a couple of seconds and it goes back to normal.
Annoying but harmless.
Chhers
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
Bumping an old one - anyone have any resolution to this - going to take mine in this week to have it checked, when I put them on the lowest rain sensing setting, they wipe slow a few times, then stop then might wipe slow one more time and then they just go on high and stay there, even if no rain is hitting the windshield, they will wipe until the windshield is so dry they will start to squeak and nothing short of turning them off stops them - have to just do manual push the button one wipe at a time for anything short of low.
7 or 8 cars with this technology over the past 10 years and this is by far the worst one, have to assume something is wrong - did have our new X5 be a bit crazy when we got it and took it in and they replaced the sensor and all went to normal, so hopefully they can fix it!
