C63 AMG (W204) 2008 - 2015
Rear axle oil
Old Feb 14, 2012 | 06:49 PM
darmawaa's Avatar
2011 E63 AMG
Rear axle oil
What oil should I use in rear axle? 75W90 or 75W140
I've installed Quaife LSD, and my car has Weistec supercharger (650hp)
Is thicker viscosity has better load protection for the gears?
Our weather is 75 deg F all year long (no winter)
Old Feb 16, 2012 | 12:27 PM
MTLdude's Avatar
2005 CLK 55 AMG
I think thicker oil protects a bit less than thin oil because it penetrates less. I used MB diff oil when i did my Quaife install and i don't know what it is. Maybe you should do the same.
Old Feb 16, 2012 | 12:56 PM
Vic55's Avatar
Administrator
This.
Is what I used on my 2012 CLS63TT with LSD---- got it from the dealer:
Old Feb 16, 2012 | 11:46 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
I would have disagreed on the Castrol you bought and said it should have been SAF-XJ. But then I found this:
Product code: CAS-1821-7160. Castrol Syntrax Limited Slip 75w-140 Axle Fluid 1821-7160 1 Litre. REPLACING Castrol SAF-XJ Castrol Product Features * Castrol Syntrax Limited Slip 75W-140 is a full synthetic hypoid gear oil formulated for use in both conventional and limited slip differentials. * It has demonstrated outstanding performance in competition vehicles employing limited slip differentials. * It is approved for use in the high performance BMW-M Series and Mercedes Benz AMG limited slip differentials. Advantages * Reduces noise and vibrations in the axle. * Excellent shear stability maintaining performance over the life of the lubricant. * Exceptional stability at high temperatures extending the life of lubricant and axle. * Effective wear resistance ensures protection under high loads and prevents damage to components. * Very good low temperature fluidity properties increases protection at start up. Castrol Product Code- CAS-1821-7160 Bar Code- 4008177071744
The last time I bought the SAF-XJ was at a BMW dealer who sold it for half anywhere else if you brought your own container. They would pump it from the 55 gallon drum.
