C63 AMG (W204) 2008 - 2015
Correct Tire Pressure
Old Nov 17, 2012 | 10:06 PM
HoozyerdaddyC63's Avatar
C63
39, 41 regular driving and 39, 26 when I'm at the dragway.
Old Nov 17, 2012 | 10:16 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Fronts-40
Rears-39
The tires are wearing evenly.
Old Nov 17, 2012 | 10:25 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
Wow, those numbers are really high. I worry about high pressured tires being more prone to pick up debris and leading to flats.
What is the recommended minimum pressure on the fuel door for C63?
Old Nov 17, 2012 | 11:23 PM
Guilty's Avatar
'16 C63-S
36 all over. I pick up too much debris and nails if higher.
Old Nov 18, 2012 | 09:28 AM
Dogtag114's Avatar
2009 c63
Although the chart didn't paste well, I found this on TireRack.
It appears the higher pressures are recommended for Higher Speeds...
Recommended High Speed Pressure & Load Capacity Adjustments
For Z-Speed Rated Tires
(tire manufacturer must confirm speed capability beyond 149 mph)
Vehicle
Top Speed Required Tire
Pressure Increase Tire Load Capacity
% of Branded Maximum Z-Speed Rated Tire
35 psi O.E. Example
mph km/h psi bar % of value branded on sidewall psi lbs.
118 190 0 0 100% 35.0 1000
124 200 1.5 0.1 100% 36.5 1000
130 210 3.0 0.2 100% 38.0 1000
136 220 4.5 0.3 100% 39.5 1000
143 230 6.0 0.4 100% 41.0 1000
149 240 7.5 0.5 100% 42.5 1000
155 250 7.5 0.5 100% 42.5 1000
161 260 7.5 0.5 100% 42.5 1000
168 270 7.5 0.5 100% 42.5 1000
174 280 7.5 0.5 95% 42.5 950
180 290 7.5 0.5 90% 42.5 900
186 300 7.5 0.5 85% 42.5 850
NOTES: Never exceed the maximum cold inflation pressure branded on the tire's sidewall.
Old Nov 18, 2012 | 10:12 AM
gthal's Avatar
2012 C63 coupe
Tire pressure isn't just about speed but also load rating. Bottom line is you should stick close to what MB suggests as it takes into account weight, required load, etc.
I;m curious as to how does a high pressure cause debris to be picked up? I would think a lower pressure would do this as the tread would "sag" and be more prone to debris.
For me, I stick with 42 as is gives even wear and maintains the required MB load rating (according to Tire Rack). Deviating from what the manufacturer suggests by a lot (e.g. 36) doesn't make a lot of sense to me unless there are specific reasons (drag strip, track use, want a sloppy/cushy ride and don't care about the other stuff). I also found the car felt sloppy below 42. The sidewall flex was too much and the car felt less tight. That might be OK in an E/CLS/CL but not in a C
Bottom line though is there is a lot of personal opinion on this and very little is based on any real evidence or fact (including my opinion).
Old Nov 18, 2012 | 07:22 PM
  #32
otakki's Avatar
Interesting phenomenon, isn't it?! However, it's actually well proven and you can find that info on many sites, books, and magazines. I'm also curious as to how exactly that works. If I remember correctly, it has to do with how the increased stiffness has a tendency to throw debris upward and also stand linear debris like nails on their ends, with the fraction of a second just long enough for rear tires to roll over them and cause punctures.
I used to think a lower pressure would be less likely to pick up debris, too. I used to get a lot of flats (esp passenger side rear tire) in my old cars and came to found out my tire pressure meter caused me to overinflate. Then I got a digital Accutire one after reading Consumers Reports as well as a new set of tires and never had a flat since then. But the new tire model might have something to do with it.
Old Sep 2, 2013 | 08:52 AM
  #33
TomSu's Avatar
2010 c63 amg
O well I got a tire pressure question too
After driving on the highway for an hour or so.. My driver side rare
Tire pressure is 49. And fronts are like 43. But just one rare tire is 5-6 points higher than the rest.. Should I be concerned ?
Old Sep 2, 2013 | 08:54 AM
  #34
TomSu's Avatar
2010 c63 amg
Rear* sorry about the typo
Old Sep 3, 2013 | 06:28 PM
  #35
otakki's Avatar
One tire shouldn't have that much higher pressure than the other three. I have a feeling the TPMS is going haywire and sending out erroneous signals.
Old Sep 3, 2013 | 07:35 PM
  #36
Ingenieur's Avatar
C63 AMG
my passenger door sticker only has one set of numbers
F 41
R 45
the gas flap says
low load 39/39
full load 41/45
but it looks like this is for 225/45/18 all around M&S winter tires?
it says when warm +4 psi F & R
I'm running tires that have a higher load rating
when reading the oem pressure/load from a load/inflation chart I get 39/41 for my tires when I equate the oem load to my rating...that is what I run
seem to be wearing very evenly, did a chalk test
Old Sep 4, 2013 | 01:44 AM
  #37
Edrshop's Avatar
09 C63 13 R6.36
Benz I'm finding likes em up. I run same DWS Conti on all my rigs (M3's, NSX's, X5is) and they all ran much lower but my C63 (low! On H&R and 19" rims 275/30) rubbed badly 35! Now I bumped to 41 front and 45 rear no rub and rides/handles fine. It's a street car not my race bikes where grip is key & 0.25psi is huge. No reason 41/45 or close is "too high"
Oh I don't care about wear either. I mean enough min roll on burn offs for fun kinda defeats worrying about mileage
Old Sep 4, 2013 | 08:23 AM
  #38
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
I'm currently running 44psi all around. I used to have it lower in the front, but after some tough encounters with SF roads, I beefed it up. I'm also only running 245/30 up front. If I had a fatter tire, I wouldn't have to worry about dinging rims.
Old Apr 28, 2014 | 09:00 PM
  #39
AMG Boost's Avatar
2010 C63 P30
On the stock Perelli P Zero 18" I ran a 38psi front and rear and my rear tires are worn in the middle only. Hmm weird. Maybe its the type of tire. Going with PSS next.
Old Apr 28, 2014 | 10:42 PM
  #40
whoover's Avatar
'19 E63S sedan
My flap says 41/41 but the TPM thinks 39/39.
I set the cold tires with an accurate gauge to 41 all around and recalibrated the TPM. It read 39/39. Very annoying. I had to drop the pressures to 39, reset the TPM and then bump them to 41. Not a big deal but stuff like that irritates me.
Old Apr 29, 2014 | 01:16 AM
  #41
8o8is's Avatar
'10 C63
My rears are wearing the same. I got @6k on the rears and now down to the wear bars, lol.
Attached Thumbnails Correct Tire Pressure-ds_door_jam_tire_psi.jpg   Correct Tire Pressure-gas_flap_tire_psi.jpg
Old Apr 29, 2014 | 10:26 AM
  #42
Dogtag114's Avatar
2009 c63
Same thing happened to me on the Zeros but I'm getting more than twice the miles with half the wear on my PSS.
Zeros in rear lasted 7k miles.
Old Aug 6, 2014 | 03:27 PM
  #43
Spearsba's Avatar
2011 C63 P31, 2012 ML350, 2007 335i E93
Similar here. Bought mine in Jan 14. Brand new Michelin's all around. Last week with 9k miles I replaced the rears. Fronts look brand new. My rears were worn badly in the middle (indicates over inflation) I had been running 42 all around. However at operating temps the pressure jumps 5 to 7 lbs. I'm in Alabam wher ethe temps have been in the lower 90's. With my new rears I lowered to 37 in front and 39 in rear. Still at operating temp pressure jumps 5 to 7 lbs. So running at temp about 45 lbs in rear. Any opinion if that pressure will lead to the tread wearing out in the center from overinflation.
I also found 9K miles on the rear a bit extreme as I don't race it. I have never lit up the white smoke. Just normal spirited driving...
Old Dec 22, 2016 | 11:07 AM
  #44
geeves66's Avatar
S55 AMG
pressure up!
I have a s55 AMG...with that said...i was running recommended 33 and 35. I find that way too low. You can see where the tire rolls on the sidewall wear due to corners and raising and lowering the car auto in sport. I find i get less wear with higher pressures but the ride is going to suffer a bit. I raised my pressure 6 psi above what was recommended and tire wear on outsides were reduced. Just my 2 cents.
Old Dec 22, 2016 | 11:37 AM
  #45
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Thanks, now I can sleep at night. Whew! Great first post!
Old Dec 22, 2016 | 01:22 PM
  #46
604 C63's Avatar
2012 E550 Cabrio
About bloody time an S class owner checks in to help settle this.
Buddy joined in June 2014, and the last post in this thread is August 2014. He was thinking about what he wanted his first post to be for a reaaaaaaaaaaaaally long time, and finally got it just right.
Old Dec 24, 2016 | 01:26 PM
  #47
507OverBiturbo's Avatar
C63 507
Originally Posted by Pickles
Definitely too low....IMHO.
Don't forget you're running low profile rubber, & with that low pressure, you are lessening the "cushioning" barrier that you need to protect your rims if you hit a rock or something.....you are more likely to suffer tyre damage which can then more easily transmit to the rim....I'd be going a MINIMUM of 38.
Cheers, Pickles.
Yeah I've got the 19" on my 507, if I ran at 34 I'd be replacing tires daily. I run 42 all around, but that's for DD. I haven't had any over-inflation issues on my PSS, which, amazingly, have lasted me a full year and about 20,000 despite my 'spirited' driving. Guess it's time for the new Mich PSS replacement tires though.
Old Nov 14, 2018 | 04:06 PM
  #48
hcj06870's Avatar
C63
Two different questions here: 1) What is the correct tire pressure for street? 2) What is the correct tire pressure for track?
1. While the label on the driver's door jamb shows 41/45 front/rear, the fuel filler door label shows that this is for 5 people and luggage. Under normal conditions, the figures are 39/39 front/rear.
2. At the track, you must have a tire pyrometer to properly set tire pressures. The trick is to drive the car then quickly check the temperature of each tire (use the stick-in probe, not the IR laser) at the outside edge, middle, and inside edge. Average the outside and inside edge temperatures; if the middle temp is lower, then the tire is under inflated. If the middle temp is higher, then the tire is over inflated.
This is the ONLY way to correctly set the tire temperature at the track. Frankly, this is how to also do it under normal road conditions, too, regardless of what the fuel filler door says. Clearly, the idea is to have ALL the tire contact patch working equally, which means that temperatures are even across the fact of the tire. If the middle of the tire is working too hard, grip is compromised (since the edges aren't working hard enough). BTW I'm a mechanical engineer and instruct for the Porsche and Mercedes clubs
You'll notice that often the inside and outside edges of the tires have different temperatures. If the inside is running hotter than the outside, then you have too much negative camber and you need to dial it out. If the outside is hotter, then there's not enough caster and in corners the tire is rolling over. Good luck on this, though, as I don't believe camber is adjustable on the W204.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
