WOT Shifting Issue at Drag Strip
Sweet, you're going to be there at the Airstrip Attack? I will be there. It should not happen at the event, it is a rolling start and you should already be in 2nd gear. Are you running DR's or street tires at the event? I am going to experiment with both set-ups, but since I could spin my street tires up to over 100mph back in October and now I have added an additional 150+whp I think the DR's are going to be the way to go. I'm just not sure about the skinnies up front at 200mph
As for tires, I just put on a new set of Nitto 555Rs for the event to ensure I get no wheelspin punching it at the start of the roll-ons. Running stock tires up front and stock rims all around. The event is gonna be epic!
Looking forward to meeting you Jim.
Yep, I'm gonna be there, and I can't wait!!! I'd love to video a run of our cars so people can see how the Weistec Stage 3 package demolishes a Stage 2 C63 car.
I would be happy to line up with you for a cool vid. I have a couple GoPros and we will have a VBox with us as well. My goal is to break the 200mph mark. in doing some research on other rolling half mile events and the weight of my car and the HP I am making I think the car should be good for at least 200mph. Obviously there are some other variables that are out of our control such as wind and DA that will come into effect. My car was doing 136mph in a standing 1/4 mile do a 50mph roll-on 1/2 mile is going to be a ton of fun.
I've had this happen on the street when I punch it sometimes from 1-2. Feels like I hit the rev limiter. Car stops then takes off again, almost gives me whiplash.
Does this effect the MCT guys? I'd say the TCU isn't perfectly able to adapt to the power increase...
#32
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
we figured out the solution on the 55 platform, and it should easily transfer over to the 63. A ECU reflash that would be needed, and remember that we always have offered FREE retunes! We will contact a few customers to have the 63 retuned, to verify and let you know.
#33
Hmmm, so does this mean all the other major tuners need to figure this issue out too and adjust their tunes accordingly?
#34
SPONSOR
Can't answer that question really, I guess it all depends on their process and if they have the access to that part of the ecu.
#35
2007 E63 w/P30 and Eurotech CF Diffuser
I HAD this problem on my E63.
It was easy to make happen in the following way. Put in S, select 1st, speed up to 4000 RPM, and then floor it. The tranny (722.9) simply can not shift fast enough to avoid the rev limiter. Same thing happens if you do this in second.
The problem magically went away after I had attended the SL65BS press launch at Laguna Seca. The car also seemed to be a little quicker after that.
Odd that Mercedes has not solved the problem since I am sure they know it happens. It may be that having the transmissions shift fast enough to avoid the limiter can reduce transmission life.
JRCART, you know more about the strength of these transmissions than anyone outside MB, what do you think?
#37
#39
yes it happens and is not new...its just people dont talk about things..
Only way to fix it from the user side is to use M mode and shift slightly earlier to make sure you don't hit the rev limiter, until you get better at it GL
#40
2008 A8L, 2002 996TT X50, 2009 X5
...ummmmm you're gonna get wheelspin. The airstrip is not a race prepped surface, no VHT, all you are going to have to rely on for traction is the other rubber laid down by other cars. It's a 50mph rolling start, if I punch it at 50mph I lay two dark patches well beyond 100mph so it's going to take a few runs to get a feel for the race surface and rolling on the throttle.
Think of it this way: at standing one-mile events, cars that normally trap in the high 120's in the quarter, might break into the 180's at the mile mark. So, by 1/4 mile in, they might already be at 125ish, and with a full 3/4's of a mile to go, only reach 185ish. That's only 60 mph added on in the final 0.75 miles.
By comparison, you're talking about starting at 50 mph, and then adding 150+ mph, in a half-mile stretch. Sounds like a tall order.
#41
I'd love to see it happen, but I think it's going to be tough to break 200 mph at the Airstrip Attack.
#42
I have no idea what to expect. I did some research and found some of the following speed from other rolling start half mile events.
2007 Viper w/turbo 1000 crank hp 203 mph
2010 Corvette ZR1 900 crank hp 194 mph
2004 996 tt 890 crank hp 205 mph
Obviously wind, elevation, incline/decline, DA, weight gearing and a bunch of other things are going to factor in. My car is close 1000 crank hp and has a similar drag coeffient of the ones listed above so who knows??? That being said I also found some 1000 crank hp cars with speeds in the 180mph range. Its going to be fun no matter what, hopefully I can represent and post up some respectible speeds for all the AMG guys.
#43
...one more thing, I was trapping at 136mph in the quarter mile last year when only making 660rwhp, that 136 mph in the quarter mile from a dig. Now add an additional 140 or so rwhp, a 50mph rolling start and a half mile.
#45
Look forward to the results, and regardless of what the trap speeds are, good luck and be safe out there.
#46
You mention those were half-mile rolling-start trap speeds. Do you know if they all started at 50 mph or lower though? The airstrip attack site mentions the rolling start is 25 - 50 mph... so 50 is the max.
Apparently, you guys are going to get a 1.8% decline, so that should help a lot. The 1700 ft elevation won't be ideal, but shouldn't hurt a boosted engine too much.
#47
#49
