C63 AMG (W204) 2008 - 2015
Forgestar… Why discontinue our offsets??
Old Feb 28, 2012 | 07:42 PM
16NiSSC350's Avatar
Mercedes-Benz AMG GTS
So im still in a huge bind over this Forgestar F14 situation. After one of my rear wheels being damaged beyond repair, I can't order a new 19x10 +50 because they have discontinued that offset. So here's my question…
If i ordered a 19x10 +44 (highest they make now) is there anyway I can have a wheel shop machine the offset somehow to make it a +50? There are multiple wheel shops here in DFW, but clue which one to use.
Anyone have any ideas?
Old Feb 28, 2012 | 08:05 PM
CampioniShop's Avatar
Former Vendor of MBWorld
Technically yes, but it would be outside's of Forgestar tolerances for this wheel. You would no longer be covered under warranty and there's no way to know the effects it might have on the wheel.
However I find this strange, even though it is indeed +44 at the most, we did cut a set of 19x10+50 in November and it was fine. Did you call Forgestar directly?
Old Feb 28, 2012 | 08:09 PM
_AMG_'s Avatar
C63
I'm sure there are machine shops out there that can machine them to your specs.
I think member: Tator also machined his hub plate on his HRE's to make them fit.
Its definitely doable.
Wonder why they discontinued that offset.
Old Feb 28, 2012 | 08:17 PM
16NiSSC350's Avatar
I sent an email… waiting to hear back.
I have no idea why they would discontinue that cut. Beats me
Old Feb 28, 2012 | 08:31 PM
Girard@ACGautomotive's Avatar
a car
Normally it is not a good idea to shave off more then 3mm or the back pad of any wheel. Keep in mind that by shaving off the material from the back pad you are thinning out the metal between the seat of your mounting bolt and the back pad. If the wall becomes too thin it is not going to be strong enough and the bolts can actually brake through the back pad. Talk to Forgestar about it.
Old Feb 28, 2012 | 08:36 PM
SupraJZA80's Avatar
1997 Toyota Supra TT
Do NOT re-barrel your ONE PIECE expensive wheels. In order to increase the offset of your wheel, you will need a re-barrel. Check here: http://www.memoryfab.com/blog/view/2
Most shops will not even do once piece wheels, because they were never meant to be taken apart. I know wheelflip in LA might, but I do not recommend it at all. Increasing offset is always annoying.
Old Feb 28, 2012 | 08:37 PM
Even Money's Avatar
'15 VW GTI
You may have to just eat it, and get a proper quality set of rims. You get what you pay for, they're not even hubcentric. No way would I machine them to make them fit. Forgestar had a big issue with their load ratings so this doesn't surprise me.
Old Feb 28, 2012 | 08:55 PM
16NiSSC350's Avatar
Thanks for the advice fellas!
Old Feb 29, 2012 | 02:16 PM
Got some news.
The highest they can do is a 19x10+48, anything higher will compromise the integrity of the wheel.
You would need to change out your rear set completely.
Old Feb 29, 2012 | 03:49 PM
PetroC63's Avatar
2012 CTS-V
Got some news.
19x10 +50 was a popular size for the C63 and Forgestar sold a fair amount wheels in that offset, should owners be worried?
Old Feb 29, 2012 | 06:12 PM
bluejae's Avatar
'10 C63
get a new rear set... keep the single +50 and put it up for sale... wait for someone else who has a +50 to F up a wheel and then you have a buyer... you now have a rare offset wheel... maybe you can auction it off...
either way, that sucks that forgestar discontinued it... good luck
Old Feb 29, 2012 | 06:33 PM
No issues - the former blanks were engineered to go as high as a +50. The new blanks have lower offsets for a wider - low offset car selection. I wish MB just offered a wider body for the AMG cars like the Ms!
Old Feb 29, 2012 | 07:36 PM
16NiSSC350's Avatar
I think this is the best game plan. 1 problem though… the 2012 F14 is a different design than last years model.
Old Feb 29, 2012 | 11:41 PM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
Also consider from my experience - forgestar may not be able to perfectly match the color and finish on your new wheels. They screwed up 1 rim from my brand new wheel order and the replacement does not look the same. So I'm *** out and paying to have all 4 BRAND NEW wheels repainted.
Old Mar 10, 2012 | 09:24 PM
Cyan 740i's Avatar
SL55 Widebody
Forgestar still makes that fitment. Just place an order through your dealer and they will order the correct fitment for you.
Old Mar 10, 2012 | 09:26 PM
^^Nop, highest they are willing to do is a +48 and that has always been the offset they have made for C63s - as confirmed by Forgestar themselves a few minutes ago (yes, that's correct, they even work on a Sat night ) !
Old Mar 10, 2012 | 10:01 PM
mtlcls500's Avatar
c63AMG Coupe
I was told they make the wheels to order ? Im sure they can do whatever offset you want
Old Mar 10, 2012 | 10:14 PM
Even Money's Avatar
'15 VW GTI
^ Incorrect.
