C63 AMG (W204) 2008 - 2015
Weistec new Bullet proof 722.9 transmission handles 1000 ft/lbs
Rating: Thread Rating: 2 votes, 5.00 average.
Old 04-26-2012, 07:48 PM
  #176
C63fan's Avatar
C63 w/p30; MHP ECU tune+header+mids+CF air intake duct+Akrapovic+wide body kit+ Vorsteiner VS110
Looks great from video clip! Can't wait for the real run after a little "run in" the new tranny, especially for NOS on the track!
Old 04-27-2012, 10:37 AM
  #177
GeorgeSmooth's Avatar
C63
Looking awesome. To me it seems the shifts are far faster.
Old 04-27-2012, 12:33 PM
  #178
PetroC63's Avatar
2012 CTS-V
They are insanely fast.
Mine shifts just as fast as in Keith's video.
Old 04-27-2012, 12:43 PM
  #179
BAD430BENZ's Avatar
360 Modena TT
you got your tranny done also ?
Old 04-27-2012, 01:29 PM
  #180
jacob502's Avatar
2008 C63 ,2009 SL 63 AMG, 2011 SLS AMG
He purchased the torque converter and Valve body upgrade
Old 04-27-2012, 02:06 PM
  #181
PetroC63's Avatar
2012 CTS-V
What Jacob said.
Old 04-27-2012, 03:04 PM
  #182
rage2's Avatar
C63 BS, GLA45
Originally Posted by Even Money
Couldn't you just swap in the axles from the E63? That's what they did for the C BS.
Won't work. The C BS got more than just axles from the E63, the whole back end there is like an E63 but with coilovers.
Old 04-27-2012, 04:24 PM
  #183
dodger63's Avatar
2013 f250 6.7 diesel
How was the track last week? You said you were going Thursday or Friday did you get good results how were the 60'
Old 04-28-2012, 09:00 PM
  #184
Dads C63's Avatar
2014 Audi RS7
Just a quick update:
Got the tranny installed and rented Bradenton yesterday expecting to put down some new times. However, we ran into some unusual tranny related issues. We did manage to eek out a 10.274 @ 138.54 and 10.31 @ 138.27. We are going to have the shop reset some adaptives that go deeper than I could do at the track. Then back out again.
Good news - running N/A was very good. In over 80 degree heat, +1500 DA, and over 50% humidity we had four passes in the 10.9 range and all four had 60's in the 1.5xx. The best was a 10.91 @ 127mph. The 60' was 1.562. However, I had a 10.944 @ 126.81 with a 1.54 60'. All the N/A runs were strong and the new tranny and converter performed well.
The challenges started running nitrous with the additional HP and torque. Steve at Weistec is working with me to get things resolved. I will keep you updated as I know more. Hopefully we can get it done this week.
Old 04-28-2012, 09:11 PM
  #185
Sirex63's Avatar
C63
Congratulations Keith , it's obvious that shifting has improved. Guess i'm next !
Thanks to Weistec.
Old 04-29-2012, 03:44 AM
  #186
jacob502's Avatar
Keith, I am surprised that you took it to track this fast. I could be wrong, but shouldnt you put more miles on your car to get the new trannyfully adapted?
Now you have a new transmission. I would think you need at least 250-300 miles of hard miles for the new transmission to adapt. What do you think?
Your tapping 138mph and making 10 second passes @ 80F, which is excellent. I think you could hit 9 seconds with the same conditions when the tranny adapts.
Old 04-29-2012, 03:51 AM
  #187
Sirex63's Avatar
C63
+1
I guess Keith was so excited and couldn't wait for another 300+ miles.
I'm sure he's going to record more videos after the adaptation takes place.
Old 04-29-2012, 08:08 AM
  #188
Dads C63's Avatar
2014 Audi RS7
REALLY, you and Sirex63 crack me up. With something this new and important don't you think I was communicating with Steve at Weistec regularly?? If you read my post above I said I drove it to work. Then I went out and drove it just as Steve instructed and it performed very well.
I made over 10 passes N/A prior to turning on the nitrous and it performed flawlessly. See the slips below.
Then when we added the extra 200RWHP and 250RWTQ it began to slip. We reset the adaptives at the track and it would perform better the next run but after that it was back to slipping. We would reset the adaptives and it would perform better the next run and then the next run would slip. We went back and forth until it no longer recovered when we reset the adaptives. No one is exactly sure why it was slipping but I am working with Steve to get it resolved. I'll keep you updated.
Old 04-29-2012, 08:32 AM
  #189
RNS-11Z's Avatar
09 C63
How do you reset the adaptives
Old 04-29-2012, 12:54 PM
  #190
PaulWdz's Avatar
CLK63 Black Series
That is strange. What exactly does Steve think is the problem ? Are you running the Weistec ECU tune ?
Old 04-29-2012, 03:54 PM
  #191
Dads C63's Avatar
2014 Audi RS7
You turn the key on without starting the car and then press the gas pedal to the floor and hold for at least 10 seconds. Then while its depressed you turn the key off and then release the pedal. Then let the car sit for at least two minutes according to Steve. It seemed to work for one run and then it would slip the next, etc., etc.....
I am running the MHP cam tune which Steve reviewed and said was excellent so no software challenges.
I believe I am the track test mule so we are working through the issues together. They have other cars out there with similar power levels to mine but they are running street tires or drag radials that will spin and not slicks like I am that are not forgiving and put extreme stress on all the parts. Big difference in the two. Hopefully there is a solution.
Old 04-29-2012, 03:59 PM
  #192
propain's Avatar
See Sig
Refund?
JK... hope you work it all out. With the extra 200/250 with the shot what kind of power are you are putting through the tranny?
Old 04-29-2012, 04:38 PM
  #193
dodger63's Avatar
Originally Posted by propain
Refund?
Def not what the title says
Old 04-29-2012, 04:40 PM
  #194
PaulWdz's Avatar
CLK63 Black Series
When you say slip, what do you mean ? What is slipping, clutch paks ?? Sounds like torque limiting in the TCU is taking over maybe ?
Old 04-29-2012, 04:51 PM
  #195
propain's Avatar
See Sig
Close though... Id say about 900 at the crank with 20% loss.
Either way, under whats in the title.
Old 04-29-2012, 05:11 PM
  #196
mthis's Avatar
Anything W/4Wheels
you let someone else look at MHP's tune. OMG what's Andy going to say now that his best tune ever ever ever is stollen from weistec lol.
Old 04-29-2012, 05:14 PM
  #197
Merc63's Avatar
C63 AMG
That's a lot of power to be putting to the ground with a dead hook. This is wayyy beyond what the car was ever designed for.
If anyone can figure things out it is Weistec.
If you look at any muscle cars running 700RWHP they have all kinds of special goodies to get that power to the ground and even then they are still breaking stuff.
Old 04-29-2012, 05:15 PM
  #198
neliconcept's Avatar
x5 50i
Hope you get it worked out, I have been following this thread (and the BS involved in it). Should go for a run whenever I get the Viper back in shape, I was pulling 9.2s with it, I want to get into the 8s soon before I break something else. (from South Carolina, and go down to FL every so often, car is in SC)
Old 04-29-2012, 05:21 PM
  #199
Merc63's Avatar
C63 AMG
Id say we should be grateful that a company is actually developing products for the M156 instead of constantly judging and picking apart their work.
Trying to launch a car on 315 drag slicks puts huge stresses on a drive train.
Old 04-29-2012, 05:28 PM
  #200
dodger63's Avatar
As far as I'm thinking the car isn't running 315 slicks and isn't spraying off the line, the slipping I'm assuming is coming in the 1-2 2-3 shifts lmk if in wrong
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Weistec new Bullet proof 722.9 transmission handles 1000 ft/lbs
