How to change plate lights 09
http://store.ijdmtoy.com/Mercedes-C-...e-led-a-s3.htm
Here are the instructions:
http://store.ijdmtoy.com/Mercedes-W2...-DIY-a/198.htm
If you do it yourself, here are some tips from when I did it...
--Start with the car/lights off
--You'll need a medium-sized star screw driver/wrench
--You'll need to remove your license plate
--It's much easier to remove the trunk trim where the handle release is AFTER you take apart the inner lining and reach inside. There are several plastic bits that you need to squeeze to release. They snap back into place when you reinstall it. Some gentle bumping may be needed to "click" them into place. There are also some anchors (mine were yellow) that you also need to release. Pliers work well here. Be careful not to scratch your trunk with the edges of the trim. It should pull slightly down and out, away from the trunk. There are also 2 more star screws INSIDE of the trunk where you would have released the other clips. I had to use a wrench attached to a star key to remove it. Otherwise, the trim will not come off.
--I would recommend some electrical tape to make sure they stay in place. The stock bulb and housing screw and lock in like the other smaller trunk light (disconnecting that might make it easier to access the behind-the-trunk space too). These LEDs just plug in and hang until you reassemble everything.
I would be too long to do a tutorial, but it is fairly straightforward. The tricky part is removing that trim piece from the inside. You really have to pull the lining out of the way and sort of lean backwards into it (like a glamorous pseudo-limbo pose).
Just remember the 2 star screws you need to remove inside of the trunk behind the trunk release latch, otherwise, the trim won't come off. And the (mine are yellow) anchors that you need pliers for to also remove the trim. Once you get in there behind the lining, you'll see what I mean.
