C63 AMG (W204) 2008 - 2015
M156 head bolt problems
Rating: Thread Rating: 3 votes, 5.00 average.
Old 05-12-2013, 11:26 PM
  #351
Critter's Avatar
07 E63 + 07 CLK63CAB
Quick question,
Any owners of 07 AMG M156 engines having head bolt failures, any details would be appreciated
Thanks In Advance.
Old 05-16-2013, 12:40 PM
  #352
AWD_AMG's Avatar
Scooter
Hey guys...just wanted to point something out, as this has NOT been discussed yet.
The understanding has been that all 08-09 C63s have the old headbolts, and that a significant number of 2010s do as well, but that the 2011 models are safe. The engine number cutoff is 60658.
I previously mentioned that I had not found a 2010 with the new headbolts, and I just found something a bit uglier:
I ran the VIN of a 2011 C63, reflecting a delivery date of 07/06/2010 in EPC. This car has been identified as a 2011 model in both autocheck and carfax. Anyone want to guess which side of 60658 it sits on? I'll give you a hint, it's below 60500.
In conclusion, ALL 08-10 C63s have the old headbolts, INCLUDING very early 2011 models.
Old 05-16-2013, 01:51 PM
  #353
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
That is a very troubling discovery.
Old 05-16-2013, 02:30 PM
  #354
Sincity's Avatar
WOW!
Old 05-16-2013, 02:41 PM
  #355
LAMB09's Avatar
2011 C63 AMG
my 2011 was produced in late 2010 the engine number is 156985 60 062400 does this mean I am in the possibly affected group?
Old 05-16-2013, 02:45 PM
  #356
Jasonoff's Avatar
Received 1,594 Likes on 938 Posts
2010 C63 AMG
Is 62400 lower than 60658?
Old 05-16-2013, 06:45 PM
  #357
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
That's a significant piece of info.
Old 05-17-2013, 02:42 AM
  #358
LAMB09's Avatar
2011 C63 AMG
LOL all the reading made me miss read the numbers that were posted.
Old 05-19-2013, 09:25 AM
  #359
Karl901's Avatar
Porsche 911 Turbo S 2014! E63S 14, Audi S8 13, CLS63 12, E550 12, C63 09, all tuned
I just replaced my head bolts. It is BS that you have to remove the whole head and replace the gasket. I just bought new head bolts and swapped, TQ each bolt out one at a time.
Kamal63 (09-13-2016)
Old 05-19-2013, 11:44 AM
  #360
Critter's Avatar
Good Job,
Did you have issues or was this preventative maintenance,
Looks like you got a few to do, which car did you a test run on.
Were any bolts broke or did you see any offset washers surfaces?
Any old style bolts that were or seemed to be torqued more than the others?
Any issues with holding cam timing?
Did you apply any sealant to the lower thread area on the new bolts and lastly was there any sealant seen on the old bolts that you removed.
Did you do replacement in any particular order, ie torque sequence.
Must have been a good feeling when you buttoned her up.
Again congrats.
Old 05-19-2013, 01:45 PM
  #361
Sidv22's Avatar
Audi A5 6MT, C63 AMG
Was this preventive maintenance?
Old 05-19-2013, 01:52 PM
  #362
motoman's Avatar
C63AMG, NIssan NX2000, Pontiac Fiero GT
Karl, We have heard this before , but no one has produced a DIY, even in text with out pics would help. Are you up for it? motoman
Old 05-19-2013, 04:23 PM
  #363
otakki's Avatar
What kind of head bolts did you buy?
Old 05-19-2013, 09:51 PM
  #364
Karl901's Avatar
I had stock MB OE bolts installed.
I did it for preventive maitance .
Renntech talk with AMG and did the work.
The next question is how much did cost?
I will have to get back to you on that.
Old 05-20-2013, 12:31 AM
  #365
Jasonoff's Avatar
2010 C63 AMG
Merc63 sort of did.
https://mbworld.org/forums/c63-amg-w...ts-thread.html
Old 05-20-2013, 02:44 AM
  #366
Merc63's Avatar
C63 AMG
Moto, it's too much to write on here. If you don't have a very very good grasp of mechanics and supply of tools I would leave it to the pros.
The cams have to be removed. You need a special mb tool that holds the cams in place to put them back. Also one cam needs another special tool to hold it with the adjuster, the other cams you can use a bolt that threads into both gears.
Once you remove the cams and put them back in, it's quite simple. It's just getting over that first hurdle.
It took us 2 days to replace all the bolts with studs. No way would I use the new mb bolts.m if your going that far use the studs and do it right.
Old 05-20-2013, 11:48 AM
  #367
motoman's Avatar
Merc, Whoa! You previously suggested the "newer" oem headbolts for daily drivers. What changed your mind? Also can the ARP studs be done properly without removing the head? Do you just goop up new thread sealer on the replacements and lower away?
What's your take on the "discovery" that 2010-2011 years also have the weak headbolts. motoman
Old 05-20-2013, 11:50 AM
  #368
motoman's Avatar
Karl, any idea what AMG said to Renntech? motoman
Old 05-20-2013, 12:21 PM
  #369
Merc63's Avatar
C63 AMG
Ya daily driver oem should be fine... But if your doing that much work and you might as well throw studs in.
The oem bolts are a one time use only. Studs can be used numerous times and have more clamping force.
Old 05-20-2013, 10:04 PM
  #370
Insomniac's Avatar
V
Can someone please check a bunch of VINs from random 2010/2011's so we can try to find out if they are all affected? Here is sampling pulled from cars for sale online:
2010:
WDDGF7HBXAF440386
WDDGF7HB6AF494364
WDDGF7HBXAF440386
WDDGF7HB5AF446287
WDDGF7HB8AF483933
WDDGF7HB1AF374732
WDDGF7HB1AF431737
WDDGF7HB6AF471070
2011:
WDDGF7HB7BF588559
WDDGF7HB6BF539448
WDDGF7HB4BF585313
WDDGF7HB5BF553387
WDDGF7HB5BF656647
WDDGF7HB9BF528816
Old 05-20-2013, 10:47 PM
  #371
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Thumbs up
Originally Posted by Insomniac
Can someone please check a bunch of VINs from random 2010/2011's so we can try to find out if they are all affected? Here is sampling pulled from cars for sale:
Here you go.
Regards,
Joe
File Type: pdf
Old 05-20-2013, 10:59 PM
  #372
roadtalontsi's Avatar
10 C six trizzle
ya forget doing it correctly. Those amg mb engineers (and every other automaker for the past 80yrs) are stupid and have no idea how to build an engine.
Old 05-21-2013, 12:06 AM
  #373
bhamg's Avatar
C63 AMG
Originally Posted by Valvestud
Here you go.
Regards,
Joe
Nice work 'stud!
Old 05-21-2013, 12:32 AM
  #374
Insomniac's Avatar
V
Yup. Thanks man.
Old 05-21-2013, 01:30 AM
  #375
Merc63's Avatar
C63 AMG
You don't need to pull the head to switch bolts/studs.
It has nothing to do with building an engine. Your simply switching fastners.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: M156 head bolt problems
