C63 AMG (W204) 2008 - 2015
Things You May Not Know
Old May 14, 2012 | 03:25 AM
Davo81's Avatar
'03 E500
There was a thread like this on a Porsche forum I was on, I thought it would be good to have one about our 63s
I'll start off; when you press and hold the recirculate button, it will close any openings, ie windows, sunroof, etc. then press and hold again to return them back to their position. Designed for going through tunnels etc.
Old May 14, 2012 | 03:49 AM
bhamg's Avatar
C63 AMG
Wow, interesting. Is that in the manual? If so I better actually take a look at it.
Old May 14, 2012 | 04:55 AM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
That doesn't work for my car, but here's a thread I've referenced frequently...
https://mbworld.org/forums/c-class-w...ts-thread.html
Old May 14, 2012 | 04:57 AM
Then there's post #25 from this thread that I referenced in another topic...
https://mbworld.org/forums/c63-amg-w...aux-input.html
Old May 14, 2012 | 05:11 AM
RNS-11Z's Avatar
09 C63
well my 09 spec has the Aux input but not the ipod connecter, how ever my friend 10 spec 11 spec doesnt have either of the options.
Old May 14, 2012 | 08:20 PM
Davo81's Avatar
'03 E500
That's what I was looking for! I thought you guys would have done that already!
Old May 15, 2012 | 10:50 AM
PatSC23's Avatar
2009 C63
5) if you have the automatic tranny, push the stick to the left and hold it there, it'll downshift to the gear lowest possible to allow you to be in the powerband to pass cars. And pushing the stick to the right side and hold it there will put you back into the normal automatic shifting mode.
Does anyone know if this works with the Left Paddle as well?
Old May 15, 2012 | 12:52 PM
Yes, and if you then hold the shifter to the right, or the right paddle, it will go back into full auto mode.
See the other thread I linked above.
Old May 16, 2012 | 02:24 PM
PatSC23's Avatar
2009 C63
So is this confirmed to work in the US? Guess Ill try it tonight - I have an '09 as well
Also - is this confirmed to work on the C63?
10) Steps to Reset the TCU. Resetting the TCU will reset transmission to factory shift points and the car will 'relearn' your driving style.
(1.) Turn the ignition key to the on (not start) position.
(2.) Press the gas pedal to the floor and hold for five seconds.
(3.) Turn the key to the "off" position (don't remove the key), then release the gas pedal.
(4.) Wait at least two minutes for TCU to reset.
Old May 16, 2012 | 05:16 PM
Harold1898's Avatar
2015 E400 Coupe
if you push the right pedal to the floor for 10 seconds when taking off at the traffic lights, you shred your licence and empty your bank account!
Old May 16, 2012 | 07:07 PM
Mort's Avatar
OMG, I am glad that only happens in OZ.
