C63 AMG (W204) 2008 - 2015
ECU tuning without cracking it open!!!
Old May 15, 2012 | 02:11 PM
  #51
rory breaker's Avatar
Yes
Originally Posted by propain
Even in a case like this with a flash tuner. If you pop the motor at 6K RPM its going to det pretty hard. If you flash the ECU back to the stock tune and tow the car to the dealer and throw your hands up you can be sure you will be caught. The first thing they care going to look for is the codes that caused the motor to blow. What RPM it went and why.. ect... When they find no codes and they will surely know something has been tampered with.
Jerry when you do officially launch this product, can you address this? I also would think that if something happened to the motor and you flashed to stock a dealer would be able to see particular parameters (engine speed, throttle %, etc) that is stored, wouldnt they?
I know you answered this with "100%" but Im curious to know some more details there, guessing many others who will buy ultimately would want to know too.
Old May 15, 2012 | 02:54 PM
  #52
propain's Avatar
See Sig
Originally Posted by Davo81
There still should be fault codes logged. You're not removing any codes, just flashing a tune. At least, that's how it used to work with the old flash tuner on our Australian Falcons.
Not really 100% on this. Maybe a tuner can clarify if a flash clears the codes.
Old May 15, 2012 | 10:00 PM
  #53
NCE500's Avatar
2007 E63, 2006 C55
63 Flasher
I had heard May 15 availability, sounds like it is very close to release. This product is going to be a game changer, very much looking forward to getting it!
Old May 15, 2012 | 11:35 PM
  #54
Jak63AMG's Avatar
2010 C 63 AMG
Originally Posted by Jerry@Eurocharged
Thanks for all the kind words!
The device is $450 plus the cost of the tune. If you have an exisiting EC tune on the car, then you will only have to pay the $450.
I will provide up to 4 tunes at no extra charge. This includes tunes for Race Gas, Nitrous, Pump, V3, BETA V4, Catless, etc.
The ECU had to be opened previously because of encryption, access codes, etc.
The dealer will 100% not be able to tell that the ECU was tuned. :-)
Thanks!
Hi Jerry, does this device work on non US market C63 as well? If it does, I'm very interested. Thanks
Old May 16, 2012 | 10:54 AM
  #55
sales@eurocharged.com's Avatar
SPONSOR
C63S
The flash does not clear the codes.
The programmer works on all 63's, no matter the market.
Old May 16, 2012 | 12:32 PM
  #56
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
hey guys, new thread posted with all the info about the device.
Old May 16, 2012 | 07:41 PM
  #57
Davo81's Avatar
'03 E500
Thought as much...
Old May 16, 2012 | 08:12 PM
  #58
_timothy's Avatar
c63
Thought as much...
has that been verified? if so thats huge
so really, with a tune that doesnt change the rev limiter, its significantly harder to detect if not completely transparent since the ecu will never record that it exceeded factory rev limitations
Old May 17, 2012 | 02:26 AM
  #59
Davo81's Avatar
'03 E500
With the Falcons here in Australia, the dealers could still tell. They had to be looking for it though. I'm thinking there are tell-tale signs that would suggest that parameters have been changed.
Old May 17, 2012 | 06:04 AM
  #60
_timothy's Avatar
c63
but only if they hadnt been changed back to stock parameters before service, right?
Old May 17, 2012 | 07:45 AM
  #61
Yes
This is what I'd like to know also. It's my understanding that the ECU stores certain values - throttle %, RPM's, speed, etc. If you flash back to stock, all the "settings" may go back to stock, but doesnt the ECU still keep these values, so that when a manufacturers rep comes in and really digs deep into the ECU, wont they find that? "Sir, I see here clearly that throttle % has gone well over 100% - how did that happen?" type thing. You guys are way more knowledgeable than me - can you address?
Old May 17, 2012 | 07:56 AM
  #62
Davo81's Avatar
'03 E500
no, apparently they could tell either way! The tuners would say there's no way they could tell, Ford would say they could tell. Mind you, on all the forums I never had an instance where someone was caught out.
Old May 17, 2012 | 08:01 AM
  #63
Davo81's Avatar
'03 E500
Exactly, that's what I think the dealers could see. I mean the ECU data logs everything, so if in the last 24hrs before the incident you've had 130% throttle or something, they'll know something's up! They have to go looking though. That's the tricky bit. if you present them with a COMPLETELY stock car, that doesn't look like a bolt has ever been touched, then I doubt they'll look. However if you give them something that's lowered with rims, carbon bits hanging off everywhere etc, they would have a reason to look...
Old May 17, 2012 | 09:38 AM
  #64
propain's Avatar
See Sig
Use the tool for that it is. A great way to flash on your own without cracking open the ECU.
Dont think you are fooling the dealers though. They will know its been tuned. Just the time stamp on the file when the flash was loaded would be an indicator. I am no expert in ECU tuning but I know systems and there is always a trail.
Old Jun 28, 2012 | 05:43 PM
  #65
pkarandi's Avatar
2012 C63 AMG Sedan
Newbie here with a 2012 C63AMG Sedan...LOVE the car! I am going to buy the EC handheld programmer and the EC V4 tune...Also found out from Jerry that the V4 tune is stable and will be publicly available this Monday next week!
As per Jerry, faster/ smoother shifts, higher shift times! No dyno chart just yet but on the way!
Old Nov 23, 2012 | 05:07 AM
  #66
hoohloc's Avatar
2009 C320 CDI
ECU tunning without removing it from the car
this is exactly what I have been looking for, where in South Africa can I take my car?
