C63 AMG (W204) 2008 - 2015
Ran The 1/4 Mile Tonight
Old 06-07-2012, 04:50 PM
SonnyakaPig's Avatar
MB
Originally Posted by WWMIndy
Temp was 78 degrees, humidity couldn't have been more that 20-30% and honestly have no idea about DA...
Where could I find that info?
Thanks.
Dragtimes.com has a DA calculator.
Old 06-07-2012, 05:14 PM
b16
b16's Avatar
2009 C63, 2000 ML 430, 1994 Del Sol Vtec
I see the OP has not discovered the multiquote function..
Old 06-07-2012, 08:47 PM
AMGTTV8's Avatar
AMG
LOL - you are very correct in your observation...
I have been on this forum forever but have yet to figure out how to use the function.. Every time another member uses it I stare in the post in amazement wondering "how in the hell did they do that"
I promise that I am nowhere near to computer illiterate, but clearly I have some learning to do!
Old 06-07-2012, 08:49 PM
AMGTTV8's Avatar
AMG
Originally Posted by SonnyakaPig
Thanks.
Found some interesting stuff!
DA was 1918 and corrected et and mph is 11.727 @ 118.959 mph
Old 06-07-2012, 08:52 PM
Guilty's Avatar
'16 C63-S
You hit for every post you'd like to quote, then you go on the bottom (or the top) of the page and you hit
Hope this helps!
Old 06-07-2012, 08:56 PM
AMGTTV8's Avatar
AMG
Hope this helps!
LOL now I feel retarded.
Thank you for transforming my MBWorld experience moving forward!
Old 06-07-2012, 09:43 PM
  #32
AMGangster's Avatar
2010 C63
Go forced induction, for 15-30k it will be the best blow job you've ever received.
Old 06-07-2012, 10:27 PM
  #33
Guilty's Avatar
'16 C63-S
No need to feel retarded, it took me some time to figure it out too lol.
Old 06-07-2012, 10:44 PM
  #34
AMGTTV8's Avatar
AMG
LMAO
Old 06-08-2012, 02:57 AM
  #35
MB
That's freaking awesome!!! That's moving.
Old 06-08-2012, 12:58 PM
  #36
PetroC63's Avatar
2012 CTS-V
If I scrub the tires well enough, no...especially when the track prep is still good.
If I roll out and run through a little patch of water, yes.
Once a good amount of cars hit the strip, then the system isn't as effective because of all the "marbles" left behind by cars running crappy tires.
It sounds like racestart works well. 1.82 60' time is very respectable especially with tire pressures at 42 psi.
25-30 psi is more ideal for a rear street tire at the track. The more wrinkle in the sidewall the better for traction to a certain point and safety becomes an issue.
Run your car in some negative DA and your ET's will drop.
Old 06-09-2012, 03:59 PM
  #37
late_bloomer's Avatar
2012 c63 sedan
Great run!
Did you notice any difference with race-start after tune?
I was wondering if the more hp/torque you have, the effectiveness will decrease with race-start.. Was not sure if mb just set a rpm level to launch or the ECU will adapt to different tires/ power upgrades?
Old 06-09-2012, 07:01 PM
  #38
AMGTTV8's Avatar
AMG
Originally Posted by late_bloomer
Great run!
Honestly have noticed no difference whatsoever. Seems like it has adapted pretty well.
I would assume that it is a function of the traction control sensors doing their job to modulate throttle position according to the road conditions etc.
Old 06-24-2012, 07:27 AM
  #39
sbce90's Avatar
C63
I went to the strip first time today, but I was wondering how you can launch an MCT car WITHOUT using racestart. It was busy so I only got one run in and used the Race Start. But if I want to experiment more then how can I play around with launching? I assume you cannot do a brakestand with the MCT as there is no torque converter?
Old 06-24-2012, 06:31 PM
  #40
driftmotion's Avatar
C63
don't get me wrong ... i think those are great times ... but i do get a kick out of street cars on the track .... seems like if your looking do hit up the track ... wouldn't a purpose built car be better??? I mean I guess you could rip out the rear seats and passenger seat to cut weight ... take the spare out, get ultra light wheels and maybe racing slicks .... But what i really want to see if you running that setup without the seats going to work
Old 06-25-2012, 03:05 PM
  #41
Former Vendor of MBWorld
oliver@velosdesignwerks.com's Avatar
AMG
Congrats on the times and good to see you are enjoying the tune. Enjoy in good health and be careful out there!
Quick Reply: Ran The 1/4 Mile Tonight
