C63 AMG (W204) 2008 - 2015
Lifter chatter on hot restarts, anyone else???
Old Nov 10, 2013 | 12:22 PM
Merc63's Avatar
C63 AMG
This is an old thread with a different car before the blower. This car was written off.
critter my temps are actually lower because weistec runs the rad fan 24/7.
Old Nov 10, 2013 | 01:01 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
Merc63, do you actually see lower running oil temps normal being approx 100-110C, what do you see during operation. These car would benefit from a prestart function whereas the engine is cranked but not fired, this would allow for a pre pressure of the oiling system and give the lifter a chance to pump up as well as give some lubricity of the cam, lifter interface as the oil gallery points at this area. I find personally that these engines fire up quickly and go to a pre determined 1200 RPM range then idle down 10-20 seconds later.
Old Nov 10, 2013 | 01:41 PM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
How hard would it be to change these?
Old Nov 10, 2013 | 03:58 PM
Mort's Avatar
Probably not to hard to change the valve buckets but you do have to remove the cams.
Old Feb 23, 2018 | 08:45 PM
eXstasy's Avatar
G63
Originally Posted by Merc63
I am getting loud lifter chatter on HOT restarts. Lifters must be bleeding down over 30-45mins and when the car is re-started, after 2-4 seconds they pump up and the engine is silent.
Its only been doing this for the last while now, has anyone else noticed this at all???
Cars at the dealer, they are trying to say a few seconds of noise is normal lol.
Every vehicle I have ever had, has hydraulic lifters and they make zero noise at all.
Bumping an old thread because this is what turned up in my search. The same exact thing happens to my engine. Strangely enough, I don't seem to have any issues with bleed down when starting the car cold after it has sat outside overnight. It's only on a hot restart after the engine oil has been fully warmed up from driving previously.
Current oil in the engine is MB factory fill. 0009898301USB6 which is apparently 5w40. Oil level is full too. Maybe even a bit above the top red marker on the dipstick.
I'm considering changing to M1 FS 0w40 and giving it a try, and maybe treating it with Ceratec at the same time. Do you think this would help?
Is it a serious issue requiring me to replace anything? (lifters, tappets?) or do I just ignore it and live with it?
Old Feb 23, 2018 | 10:12 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Old Feb 24, 2018 | 06:21 AM
  #32
Rick X Joaquim's Avatar
C63
it happened to me twice and I remember it was driven hard before that happened.
I have not experienced afterwards.
Old Feb 24, 2018 | 07:40 AM
  #33
BLKROKT's Avatar
Both of you dum dums don’t even realize you’re talking about the most discussed topic on this entire forum. Seriously. Nobody wants to hear about your lifter tick experience. Please read the FAQ.
Old Feb 24, 2018 | 11:02 AM
  #34
eXstasy's Avatar
G63
I’ve read the FAQ and I’ve been doing a lot of reading on all the topics I can find.
I use search heavily and I try not to post something new or ask unless it seems different from the rest. I found a thread that describes my exact experience so I posted in it to see if it was as common an occurrence as the other scenarios.
I don’t have extra loud lifter tick on cold start. I have it only on hot restarts. I just wanted to see if anyone had that same scenario and was able to resolve it. I went through the common troubleshooting. I’ll try some more.
Thanks for the data point.
