C63 AMG (W204) 2008 - 2015
TPM Sensors and Winter Tires
Old Sep 4, 2012 | 06:58 PM
LangeOne's Avatar
C32, 911 Carrera S(991), C63BS
For those who mount snow wheels and tires onto their cars, can you swap out the TPM sensors from your summer tires onto the snows?
Even if that is possible, it may be more trouble than its worth. I am tempted to get 4 new sensors for my snow setup.
Old Sep 4, 2012 | 07:40 PM
JeffDL's Avatar
C63
just get 4 new ones.
Old Sep 4, 2012 | 08:38 PM
BD-C63's Avatar
2015 C63S AMG
I'm getting 4 new ones when I get mine. Also, I'm planning on getting the same size wheel all around so that I can rotate snow tires.
Old Sep 4, 2012 | 10:09 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
It's easier to just get 4 new sensors. I just bought 4 from ebay. http://www.ebay.com/itm/TPMS-Tire-Pr...fbbdec&vxp=mtr
Old Sep 4, 2012 | 10:31 PM
steven1888's Avatar
2008 c350 sport
do you have another set of rim for those snow tires? if you do get a new set, yes they are reusable but not worth the trouble.
Old Sep 5, 2012 | 10:24 AM
LangeOne's Avatar
Thank you all for your reply. New TPM sensors are being installed as we speak.
Old Sep 27, 2015 | 02:15 PM
Adamliu's Avatar
2015 C63 AMG Edition 507
just changed winter tires and forgot to buy TPMS....
Old Sep 27, 2015 | 02:21 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Pre-FL Canadian cars don't use tpms sensors which I like.
Old Sep 27, 2015 | 02:25 PM
Adamliu's Avatar
it gives me tire pressure monitor sensor incorporative "no wheel sensor" light & keep flashing. I remember I didn't buy TMPS sensors for my new wheels so.. that might be the cause
Old Sep 27, 2015 | 02:52 PM
Roswell's Avatar
Replied to ur PM, and recommended u to buy some aftermarket sensors to save money. At least that's what I did for my ISF & it works flawlessly.
Old Sep 27, 2015 | 03:37 PM
red60R's Avatar
2017 C63S
for you Canadian's who drive their C's in winter, how has that worked out for you? I live in Wash DC so we get minimal snow but I have been curious as to whether I need to invest in some snows for this winter season since my wife is driving my ML most of the time.
Old Sep 27, 2015 | 03:50 PM
Roswell's Avatar
Definitely get snow tires, u don't need snow to slip & slide.. Anything below 10C can become dangerous with summer tires.
Old Sep 27, 2015 | 04:21 PM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
I got a square setup for my winter tire/wheel setup so I could rotate them front to back easily.
Downside is they are directional so you cannot swap side to side unless you get them flipped on the wheels.
Old Sep 28, 2015 | 11:07 AM
oggie's Avatar
2011 E550 4Matic & 2010 Audi Q5 & 2015 C63 507
Does car need to be programmed via Star to recognize the additional sensors? And can the car accepts two sets of sensors?
Old Sep 28, 2015 | 11:28 AM
looney100's Avatar
None
I just got a new set of rims fro my 2015 E63, and had the wheel shop provide the TPMS sensors. They were able to match the sensors to the car - no trip to the dealer was necessary.
I suspect the same would be the case for the C63.
From what I understand, no special programming is required. Mine required some attention because one of the sensors installed was dead, so the onboard system initially displayed an error.
Old Sep 28, 2015 | 11:42 AM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
I installed two new sensors in my E550 after metal caps got stuck on the stems. No re-programming was required. I made sure I got the correct part which was A0009057200.
Old Sep 28, 2015 | 11:50 AM
Bimmer777's Avatar
2010 GL550, 2013 C63
I run my winter setup without TPMS. I decided just to deal with the warning light for the winter months and monitor tire pressure regularly, which i do anyway.
Old Sep 29, 2015 | 01:19 PM
razy's Avatar
2016 AMG GTS
really? darn I did not know that!
so I have no TPMS in my 09? does that mean when I buy new wheels that require a shorter valve stem to clear the brakes I don't need to worry about it then?
Old Sep 29, 2015 | 01:20 PM
razy's Avatar
2016 AMG GTS
I'm also looking into winter tires to fit over my stock 18s, any specific tires you guys recommend or a different wheel/tire setup completely?
Old Sep 29, 2015 | 03:08 PM
Roswell's Avatar
No tpms for ur 09, just mount & drive.
And u can use square set up on ur OEM wheels in winter. 235/40/18 all around.
No programming at the dealership required for ppl who needs tpms from what I read. The car should be able to recognize both tpms if they secobd set is clone properly.
Old Sep 29, 2015 | 08:36 PM
Get a square set up so you can rotate them front to back.
What type of driving will you be doing?
Old Sep 29, 2015 | 09:34 PM
Adamliu's Avatar
Bought OEM today instead of EZ sensor. I was told I might have to go to the dealer to do the Star thing... but they (Kal tire) will do their best to make it work.
Old Sep 30, 2015 | 09:25 AM
JeffDL's Avatar
C63
i bought mine from tire rack. no need to go to mercedes. just install in the tires and the car will pick up the signal from them.
Old Sep 30, 2015 | 10:02 AM
Eric ATP's Avatar
2012 C63 P31 black/black
One for the things Merc did 100% right. No need for OEM unless you like to spend extra money. Get the correct frequency for your car 433 mhz and ur done. They will recognize and work within a few miles of driving.
Old Oct 2, 2015 | 12:44 PM
Bimmer777's Avatar
I have an OEM staggered setup but with same size tires all around. I got the tires for free practically brand new so I decided to use the setup. Its actually not bad at all on the stretch, in fact i cant even call it stretch. But in any case, I am a bit of a Michelin fanboi and use Michelin PA3 tires now. Once these go out, will move up to PA4.
