Question about C63
How much for maintenance and other service each year(Annual 10k miles).Or MB has cover warranty and maintenance like BMW? Everything free after several years from new.
Is it the same from 2009-2011 for chassis and engine?
For maintenance, you will probably be changing tires each 5-8k miles (rears), cause these cars literally eat the rear's (combination of torque + weight + narrow tires for such powerful engine). Add that to your budget. Engine oil replacement will be around 120 bucks if you do it on non-MB workshops (I do mine each 3.7k - full sinthetic). Expect throwing $300+ at an MB delarship. Fuel is another expense you need to consider. Average comsumption is on 11 - 16 mpg on mixed driving. I think MB don't offer free maintenance as BMW, but these cars are very reliable (for gasket engine troubles of the M156 you should check another thread on this forum). Also, consider the front brake pad and rotor change at 35-40k.
from 2009-2011 the chasis is almost the same, but MB offered development packages on 2010 (more HP) and 2011 (more HP, plus better brakes). Those cars are more expensive and hard to find (believe me, I tried for almost a year). 2011 P31s (dev package) brakes are more expensive to replace. Trannies remained the same for those years. Only on 2012, when the car was facelfted, it obtained a more up-to-date transmission, but it seems that is prone to overheating on race track sessions (from what I've been reading in this forum).
Good hunting!
Lol, me too...Fung63 you get extended warranty? I got 7yr / 100k.. I have a loooot of miles to drive before I do serious engine mods
You can prepay your service for first 5 years if buying new. I paid ~2500, but I still do an extra oil change between servicing. If your buying used, then this should be good for you..
Good hunting!
Not many people will buy a used C63 knowing it's probably been driven hard by the previous owner and those that can afford to own such a car usually buy it new.
Cheers, Pickles.
