C63 AMG (W204) 2008 - 2015
Error code help needed! P2610
Old Sep 29, 2012 | 12:10 AM
N1ck's Avatar
C63C
Unhappy Error code help needed! P2610
Anybody ever got this before? If so, help please!
Old Sep 29, 2012 | 12:20 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Sorry to hear Nick about your CEL... was your car shaking or on limp mode? Just have it checked at the dealership, it will be fixed under warranty in no time.
My car got a CEL the first day I picked it up, it was a bad 02 sensor... been running like a charm since then.
Good luck!
Old Sep 29, 2012 | 12:41 AM
N1ck's Avatar
C63C
Neither shaking nor limp mode I was messing with the speedometer, then I put everything back together. I started the engine and there it was! I know it's something to do with PCM...
Old Sep 29, 2012 | 12:54 AM
Rsquad911's Avatar
97 Porsche GT2 Wide Bodied Cabrio, Mercedes G500
What do you mean by messing with the speedometer?
if you unplugged something had the ignition on it could throw a code.
Old Sep 29, 2012 | 01:17 AM
N1ck's Avatar
C63C
I was trying to change the lights inside of it. After I put everything back together and started the engine, CEL just popped up. I tried starting and shutting off the engine couple times and it's still there.
Old Sep 29, 2012 | 10:47 AM
Rsquad911's Avatar
How did you get the code? Do you have a code reader/scanner?
If so why don't you just reset it?
Old Sep 29, 2012 | 10:52 AM
Rsquad911's Avatar
After some research...
DTC P2610: ECM/PCM Internal Power Off Timer Performance Problem
Possible Causes
POWERTRAIN CONTROL MODULE (PCM) SOFTWARE UPDATE
EXCESSIVE RESISTANCE IN THE PCM POWER OR GROUND CIRCUITS
You may have shorted something while having everything apart? I say just reset the code and see if it comes back. I'm sure it's nothing.
Old Sep 29, 2012 | 07:23 PM
N1ck's Avatar
C63C
I have the REV application on my iphone that can read the error codes. The CEL finally went away today after a few more starts. Thank so much your help Rsquad911!
