Best performance snow tire for c63:Michelin Pilot Alpin PA3 vs Dunlop Wintersports 3D
I keep going back and forth btwn these 2 tires that I will be putting on my OEM rims.
Has anybody ridden with both of these?
If so, any preference?
NOT the PA3 unless you never plan to drive in really bad weather... horrible in snow.
Snow performance, best to worse (adding Blizzaks to your list)
1. Blizzak LM-60
2. Dunlop 3D
3. Michelin PA3
If you plan to drive the C63 is wet snow, ice, etc then I would NOT get PA3. I had a set for one winter and then sold them they were so bad.
The Blizzak is a better snow/ice tire but the Dunlop is a pretty decent compromise.
P.S. Didn't you already have a winter tire thread started?
1. Blizzak LM-60
2. Dunlop 3D
3. Michelin PA3
It's a totally new design. I just put them on my car today. One of the guys at my shop did the weekend retreat at a ski resort in Ottawa on ice and snow earlier this year and said that they handle great. I'll have better reports myself as soon as it snows in Toronto.
Aren't you worried about wearing them down too quickly given the warm temps? I try not to put mine on until absolutely the last reasonable time as they wear quick and are too squishy until temps cool way down.
Yeah I thought about that but my shop gets so busy at the end of October for tire change overs that I don't have time to do my own car...lol. I'm not too worried about it because the morning is fairly cold. +7 and colder is the best time but hey, it's out the way and I don't have to worry about it.
What size tires did u get?
I wanted to get the best traction so i went with 225/40 all around. I was going to get 235/40 but i thought i would try the 225 on the 9 rears and to my surprise it actually is not that bad. It is a bit stretched though, but i wanted skinnier tires for the best possible traction in the winter
Would a 235/45 work or would it be too tall?
Good call on avoiding the PA3... the PA4 might be different but I'm not going to be a guinea pig this time
I went 225/40 but on 8" wheels all around. 225 will work on a 9" wheel but, like you said, will be stretched a bit. I would bet that 10mm more (245) on a better winter tire would still give better results than a 235 on a tire with less real winter capability. Personally, I would pick the tire that is best for you and not worry about a 235 or 245 size. My bet is a 245 very good winter tire will outperform a 235 good winter tire in bad weather because the tread compound and tread design would have a much bigger impact on performance than 10mm in width.
Should I go with the 235/40/18 or 245/40/18?
Update on my 235/40/18 dunlop wintersport 3d tires:
No snow yet so cant comment on that...
But as far as handling goes, not too much different than the OEM summers, which is a huge plus
Running 41 cold pressure on all 4 tires, heats up to 46 on all 4s
Is a warm pressure of 46 too high?
Running blizzak ws70 235/40/18 on all corners and it's working great
Btw just my 2 cents but if you guys are planning to drive the c63 in the winter and you will get snow in your area... Don't cheap out on your tires. And of course, drive with common sense
I also ran Blizzaks on previous cars, and the Dunlops Wintersports seem to be a nicer, all-around tire for the winter. I can't comment on its snow traction, as my new tires and my new C have not seen snow thus far.
