Where can I find an ENGINE NUMBER?
#51
Head bolt issue
WDDLJ7EB3DA079389
Can you get me the engine number for this one please? So when I got the engine number, how do I check for head bolt problem? Thanks.
#52
WDDLJ7EB3DA079389
FloridaBrent (06-20-2021)
#53
Thank you sir. That's what I thought. Only M156 has head bolt issue, not on M157. I asked for common issue in M157 in M157 forum and a member has mentioned about the head bolt and cams issues in M157. That surprised me.
#54
C63 amg i need to verify if my engine affected with head bolts issue and engine numbe
2009 MB C63 amg i need to verify if my engine affected with head bolts issue and engine number please
vin: WDDGF54XX9R053580 WRONG
CORRECTED VIN: WDDGF77XX9F221565
email: mohammedkhalaf.90@gmail.com
PLEASE LET ME KNOW ASAP JOE
THANKS SO MUCH
THANKS SO MUCH
#56
THANKS SO MUCH
THANKS SO MUCH
#57
#58
THANKS SO MUCH
THANKS SO MUCH
![](https://neuroneurotic.files.wordpress.com/2016/09/536px-triple-facepalm.jpg)
#60
Affected
Ok so it’s definitely affected. The car has over 135k miles, drives so strong, no check engine or any codes, and no coolant messages! Is there anyway it would pass 135k miles without being done?? Is there anyway to know if they’re done or not!
what’s the estimate price for such a repair job
#61
-If the tops are hollow-torx, they are the original at-risk design.
-If the tops are external-torx, they have been replaced with the updated design.
It's very possible they are original at that mileage. There are cases of 200K+ miles on at-risk bolts without issue and failures at 20K miles. If they haven't failed yet, then the question becomes how much do you value peace of mind.
As for cost, shop around in your area. The 1-by-1 replacement method has a track record on here of working and there are mechanics out there who will utilize this (figure around $2K or less). The top shops recommend the factory procedure of pulling the heads, which will cost twice that or more.
#62
#63
#66
Hi Joe,
Will you be able to help me check the following VIN?
WDBSK7AA1CF167874
Thank you kindly in advance!
WDBSK7AA1CF167874
#67
Hi Joe,
WDBSK7AA1CF167874
WDBSK7AA1CF167874
#68
Hi, I'm looking to purchase a 2011 C63. The VIN # is WDDGF7HB9BF602574 and engine model 156985 60 064039.
Is this car in the affected range of headbolt issues? Thanks
#69
You should be good. The TSB data indicates the issue affects all M156 engines, up to serial number 569xx 60 060658 and you're engine is well beyond this.
pavan407 (09-16-2021)
#70
#74
Again, all 2010 and older are in the affected group. Last 5 digits of engine number need to be 60658 or higher.
Fuertes (12-06-2021)
#75
WDBUF77X07B084233. Can anybody check this one for me?
