C63 AMG (W204) 2008 - 2015
C&D Says 5.5 BiTurbo in C63
Old Dec 9, 2012 | 01:20 PM
propain's Avatar
See Sig
Originally Posted by Merc63
How so?
My stage 3 blower is rated for 730-750 HP on stock internals. With internals 850-1000hp.
A tuned cls from renntech is rated at 670hp. Add intercooler, down pipe, bigger turbos and HP goes up, haven't seen anything as high as the built weistec stage 3 yet.
The same could be said if you put bigger turbos on the 5.5.
Stage 1 Weistec blower on a 6.3 vs what we have seen the 5.5 put down with a tune only and I believe the 5.5TT has it hands down. Never mind in a lighter platform like the C63.
Plus as we know dyno numbers mean zip. What can it do on the track is more important. You can make all the power you want, if you cant use it its worthless.
Old Dec 9, 2012 | 02:36 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
Yes, anyone can strap on a rocket, but the hardest thing is how to utilize all that energy and power. Like the good old Pirelli slogan, "Power is nothing without control."
Old Dec 9, 2012 | 05:41 PM
Merc63's Avatar
C63 AMG
M156 has almost a liter more displacement. It will make more power.
I think it's only fair to compare twin turbos to the larger 3 liter blower. Maybe compare the 2.3 L blower if it was a single turbo.
I'll meet any biturbo 63 at the track in the spring, we can put this to the test.
Old Dec 9, 2012 | 05:47 PM
BoBcanada's Avatar
AMG
But talking about efficiency 5.5 would be more gas friendly right? Just asking?
Old Dec 9, 2012 | 07:07 PM
propain's Avatar
See Sig
To say because it has more displacement and that it will make more power because of it is silly. The 6.3 is not made for forced induction. The 5.5 IS. This is why engines which have far less displacement than 6.2l can and do make more power than the 6.3. Take the Supra for example. With bigger turbos and time the 55TT could far exceed what the 6.3 blower will put out.
LOL. Kinda silly to say "Only Fair" when you are comparing two vastly different modded cars and weight differences.
What would be "Only Fair" would be to compare a C63 with a Weistec stage 1 blower with no exhaust work verse a tuned 5.5TT in a C63 with no exhaust work.
Looking at the data we already have a CLS63 (55TT) without exhaust work and only a tune would spank a C63 with a Weistec stage 1 blower without exhaust work and it weighs about 200 pounds more.
Maybe I am wrong... I am open to some examples if you wanna point some out.
Old Dec 9, 2012 | 07:40 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
I bigger motor with FI will always net more hp. Boost for boost. Put a twin turbo(same ones as the 5.5 TT) on the m156 with 18psi. It would be insane.
Old Dec 9, 2012 | 07:44 PM
  #32
Originally Posted by justthebest
Assuming numbers we've all seen in the flesh / established capabilities, the 5.5TT would destroy any blown 6.3.
Boost for boost the bigger motor will prevail.
Old Dec 9, 2012 | 09:52 PM
  #33
propain's Avatar
See Sig
In theory sure. The higher compression ratio of the bigger displacement engine however makes things MUCH more complicated and limiting to high boost thus limiting that artificial ceiling you speak of.
Playing the numbers game is easy. Actually making it work is a different story.
Old Dec 9, 2012 | 10:06 PM
  #34
Ezec63's Avatar
C63 Coupe
We are all paper racing here.. But I think the peoria that build both of them would know.. As we know weistec also has ecu and other various upgrades for the m157 biturbo engine and they've clearly stated a couple times that the blown 6.3 is the faster car and they've said the head is a much better breather, bigger displacement, and the ability to rev higher and make the most of its power band. I believe what they say as They have no reason to push one over the other as they sell both but hopefully well see some head to head videos soon
Old Dec 9, 2012 | 10:37 PM
  #35
hhughes1's Avatar
2013 Chevy 427 Torch Red
Doesn't matter.... Either setup will overwhelm the tranny before max power could be attained. Why do you think the few big power project camps have been so quiet lately??
Old Dec 9, 2012 | 10:38 PM
  #36
propain's Avatar
See Sig
Thats true. I guess we will see with time.
Its all about how strong the bottom end is and how much it can take. If the 6.2l can take lots of boost it will make more power in the end. If the bottom end of the 5.5l is stronger (Thicker cylinder walls with smaller displacement ect..) it can take more boost and put it beyond the HP the 6.2l can make even with the bigger displacement.
Its all about limits. This is why Supra's are able to take 30+psi of boost on stock bottom ends. Try that with a 6.2l or a 7.0l LS7. Boooom.
Old Dec 9, 2012 | 10:42 PM
  #37
propain's Avatar
See Sig
So true...
Old Dec 9, 2012 | 11:31 PM
  #38
Merc63's Avatar
C63 AMG
Is this why Dads is no longer drag racing?
I wonder why no one has tried the Renntech tranny?
Would like to hear from Jcart or Ecampbell regarding their tranny's and how they are holding the power..
Old Dec 9, 2012 | 11:53 PM
  #39
Ezec63's Avatar
C63 Coupe
Valid point ! I know weistec has the upgraded transmissions but other than a couple times down the strip we really don't know how well the tranny would hold up with the power and repeated abuse.. I think the transmissions in the m157 cars are the same besides new software
Propain yea I hear you brother .. Those supras have an iron block and with forged internals they can take silly amounts of boost .. The m156 and m157 both are aluminum and both would probably need upgraded internals to make all this crazy power so I think the extra displacement and higher rev ability gives it the lead for now but we shall see ! I was only quoting weistec as they have 2 horses in this race and that's what I've directly seen them say ..
Old Dec 10, 2012 | 12:00 AM
  #40
Ezec63's Avatar
C63 Coupe
Ive also heard rumors that the m157's with tunes pushing the boost up have had problems with fouled plugs and them dropping into the cylinders. Don't know how true it is .. Another thing the m157 has over us is direct injection which could help with higher boost levels and Pre ignition
Old Dec 12, 2012 | 03:21 AM
  #41
Pickles's Avatar
(a)'12 C63 P/P, LSD, 19" m/spoke,comfort pack. (b)Astra SRI.
Question
TOTALLY ...1000% supposition......no-one knows anything FACTUAL at the moment.
Cheers, Pickles.
