C63 AMG (W204) 2008 - 2015
18x8.5/9.5 BBS LM style reps $529 *NEW* from PowerWheels Pro
Old Dec 11, 2012 | 07:32 AM
powerwheelspro's Avatar
Former Vendor of MBWorld
E320
Description: BBS LM style wheels
WHEEL SPECIFICATIONS
Price: $529
Size: 18x8.5 (18x9.5 35mm also available, add $20 in purchase price)
Offset: 45mm
Weight: ~24lbs
Hub size: 66.6mm (hub rings included)
Bolt Pattern: 5x112
Finish: Silver Polished Lip
Shipping: $85
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards.
Manufacturing Defect Warranty: The wheels are made in a low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarantied to fit on your car without vibrations or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements.
You can always call us at 248 686 2035 if you have any questions.
Thanks for looking!
Old Dec 11, 2012 | 08:54 AM
moosejaw's Avatar
none
Is bolt pattern 5x114.3 offered?
Old Dec 11, 2012 | 09:04 AM
E320
Hi there,
Unfortunately we only made them in 5x112 and 5x120.
Apologies for your inconvenience,
Old Dec 11, 2012 | 10:59 AM
MIG's Avatar
MIG
C63AMG PP
Hello,
ET?
Thanks.
Old Dec 11, 2012 | 11:11 AM
E320
Hi there, the wheels are available in different offset:
18x8.5 ET35
18x9.5 ET35
18x8.5 ET45
For W204 fitment, we have done the 45mm front and 35mm rear and the car turned out very nice, no poke in the rear.
I confirmed with this wheel/tire calculator using 18x8.5 45mm in package one and 18x9.5 35mm in the second package:
http://www.rimsntires.com/specs.jsp
Clearance:Package 1Package 2SuspensionAssuming that this is OEM wheel/tire and there is no any problems with clearance on both sides >>>100% clear
Package 2 (leaves even more room than OEM) FendersPackage will stick out 10 mm (0.4'') farther. Acceptable for most cars. WheelwellsThe same.
Old Dec 11, 2012 | 12:49 PM
Mikegpr03's Avatar
C63
c63?
Old Dec 11, 2012 | 12:53 PM
E320
The wheel fitment is the same as regular W204, we can do 18x8.5 45mm and 18x9.5 35mm. Actually the rears would fit a little better, I believe the rear offset is a little more aggressive on a C63.
Old Dec 12, 2012 | 12:28 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Sorry to correct you.. but for the regular C, the offset is a bit more aggressive than the C63 offset, our offset is very high/conservative. There is no way you can fit 18x9.5 +35mm in the rear of the C63 w/o rubbing... unless you run stretched tires.
In addition, with this wheel design, we might need spacers to clear the big brakes.
Old Dec 12, 2012 | 09:43 AM
E320
Hi Roswell,
You are correct, thank you for the post, I stand corrected. I was going by experience where a local Mercedes dealership put 18x8.5 45mm F and 18x9.5 35mm R on a W204. I was worried about the rears but they called us and said the customer was happy with the setup and kept the wheels. I personally didn't get a chance to see the car so I don't know if there was any poke.
Regarding the clearance issues. I will be happy to take some shots of the inside of the wheel so we can all see the design.
We always try to do the responsible thing and guaranty proper fitment by reimbursing not only the cost of the wheels but also the shipping charges back and forth. I don't believe there is another wheel company that will do that for their customers.
Having said that we are open to shipping just one wheel to the fellow forum members to confirm clearance. if it works for them we will ship the rest of the wheels to him. And if anyone wants to try a front and a rear, we will be happy to accommodate.
At the end of the day I want to do my best to ensure that we provide the same level of service that we would expect from any company if we were the customers, even if that means us going the extra mile.
Old Dec 12, 2012 | 10:36 AM
Roswell's Avatar
Now that's what we call customer service!!
You should find someone local to you to test fit them, it would save you some $$ to ship wheels back & forth. I might be wrong, but our cars need +45 to +50 offset for x9.5 wheels in the rear.
Again, sorry for threadjacking your post! Good luck in your sale!!
Old Dec 12, 2012 | 12:37 PM
C-63AMG's Avatar
C63 AMG
Rosswel, you're correct. The standard C63 is +54 offset. If you put a +35 with a 255 you will be OK but anything over a 255 will be problematic. These are more tailored towards C class owners rather than the C63. A +35 with a 275 tire will not work and will stick out. 275 is great on the c63 for traction purposes.
Old Dec 12, 2012 | 02:12 PM
Pertplus's Avatar
Hyperion's Candy-Coated 4 x 4
Isn't putting the BBS Centercap on non-BBS wheels (even if they are "reps") some sort of infringement on BBS's trademark and brand? I can understand if a customer does it, but a business trying to sell BBS replicas shouldn't be advertising with the BBS logo. That is like advertising fake Gucci purses or fake Rolex watches, saying they're fake and then putting the real logos on them.
Old Dec 13, 2012 | 12:01 AM
C-63AMG's Avatar
C63 AMG
Pertplus, If I am not mistaken, the logos will have one minor difference from the OEM BBS wheel design and as such is OK.
Old Dec 13, 2012 | 03:54 PM
Pertplus's Avatar
Actually, it can still be an infringement and misuse of a registered trademark. That's like having the words "Nike" with a backwards swoosh.
Old Dec 13, 2012 | 08:18 PM
slfmde's Avatar
Segway
Someone try this please I can't to cold outside to mess with it. I want these.....
EDIT: Never mind wish they were 19's.
