C63 AMG (W204) 2008 - 2015
Put wrong oil in! Need help
Old 12-17-2012, 05:52 PM
w204nyc's Avatar
2017 C63S coupe '09 C63, '15 Durango RT, '14 Jeep SRT8
The light came on while my father was using my car and without calling me he tried to do it himself and put in 10w40. What can go wrong and should I get an oil change?
Old 12-17-2012, 05:57 PM
tfthach13's Avatar
'09 C63
I doubt it'll cause any problems. I use 10w50 from Redline in my car and no problems. You might need to have the car warm up a few seconds more when you start it up. Just so the oil can warm up properly.
Old 12-17-2012, 06:02 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
i assume it was just a small top off? if so, i wouldn't worry about it, as long as it matched what was in your engine as far as synthetic goes.
Old 12-17-2012, 06:03 PM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
It is always good to let the car warmup a bit at start up - that's great advice. I usually wait another 15-20 seconds after the idle settles to normal in the morning if its a cold start. Also, wait a few miles before you kick the hell out of it, you'll be fine!
Old 12-17-2012, 06:17 PM
olszowa12's Avatar
'08 C63 Estate
0w40 and 10w40 will work just fine.
Old 12-17-2012, 06:30 PM
Merc63's Avatar
C63 AMG
Depending how much he added, the oil will be slightly thicker at start up now.. Nothing to worry about unless over 2-3 liters was added.
Old 12-17-2012, 07:54 PM
w204nyc's Avatar
Thanks for the quick responses. I think he only put a liter so i hope it will be fine.
Old 12-17-2012, 07:55 PM
w204nyc's Avatar
I was a bit angry because of some nucklehead salesman telling me my warranty will get voided if i use the wrong oil so i was a little worried.
Old 12-17-2012, 08:30 PM
DuaneC63's Avatar
AMG GLC63. Audi R8
Not going to hurt anything if it's just a quart. Your salesman couldn't tell the difference between canola oil and astroglide. If it bothers you, just drain the whole pan and fill it up with 0-40.
Old 12-17-2012, 08:32 PM
w204nyc's Avatar
I found out that my father had the car in the dealership before, they topped off the oil but the light didnt go off so he put another bottle of 10w40. Does that change anything
Old 12-17-2012, 08:52 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Old 12-17-2012, 09:26 PM
tfthach13's Avatar
'09 C63
So your father put in another quart after the dealership topped it off already (assuming they really did top it off)? If so, I would recommend a bit of WOT's just to burn some of the excess oil.
But if the car is running normally overall, you have nothing to worry about.
Old 12-17-2012, 09:32 PM
w204nyc's Avatar
Yea he told me after the dealer topped ff he put another bottle so the light can turn off. I haven't been hope and I should be home to take a look at it in about two hours. Hopefully my baby is ok
Old 12-18-2012, 02:41 AM
AMG9's Avatar
2012 C63 coupe P31/LSD
10/40 is not a problem but too much oil could foul your plugs and cause other problems. I would Check oil level and drain some of it if its more than 1/2 or one quart too high.
Old 12-18-2012, 01:30 PM
w204nyc's Avatar
I just checked the dip stick an there is too much oil. Another finger over the top mark. I turned the car on and white smoke is coming from the exhaust. Any ideas what I should do now?
Old 12-18-2012, 01:39 PM
ghiaguy's Avatar
ok, at this point just change the oil. Too much oil is never good - very stressful to your engine!
Old 12-18-2012, 01:42 PM
+1. I'm not sure why your oil light was still on after you had already topped the oil. When you take it in, I'd ask about that. Perhaps, they'll look at it and MAYBE redo the oil change for free. It's worth asking, or maybe they'd split the cost with you.
Old 12-18-2012, 01:48 PM
w204nyc's Avatar
so you guys think I should change the oil or just drain it and add new oil?
Old 12-18-2012, 01:52 PM
just siphon off some of the oil. if you dont have a pump, then go ask a shop to do it for you.
Old 12-18-2012, 01:53 PM
perhaps he was referring to conventional oil vs. synthetic?
Old 12-18-2012, 01:55 PM
w204nyc's Avatar
maybe not really sure but I didn't want to take the risk. Is a 10mile drive to the mechanic ok for the car?
Old 12-18-2012, 02:09 PM
AMG9's Avatar
If you have to drive, Make sure you keep the RPMs as low as possible.
Use "C" mode and go easy on the throttle.
Old 12-18-2012, 02:17 PM
w204nyc's Avatar
I just drove down to the dealership and im getting an oil change. Just to be safe
Old 12-18-2012, 02:21 PM
ghiaguy's Avatar
best solution for the car and for piece of mind!
Old 12-18-2012, 02:39 PM
mvp2765's Avatar
C
+1. Can't go wrong with playing it safe.
Quick Reply: Put wrong oil in! Need help
