AMG Sport Steering Wheel Trim DIY - Part 1
Subscribe
Aug 18, 2013 | 07:05 PM
Thank you MB280S for this thread helped me get the B paddles installed easily
here's a picture after installation
Reply 0
Feb 26, 2014 | 11:15 PM
anyone have their old trim they'd be willing to part with by any chance?
Reply 0
Sep 23, 2014 | 07:02 PM
There is a trim currently for sale on this website, made me look at my trim.
The black AIRBAG trim piece unclips.
Is the AMG trim piece available as a separate item to clip on in it's place?
Reply 0
Sep 30, 2014 | 07:27 AM
Quote: There is a trim currently for sale on this website, made me look at my trim.
Would be interested in this also!
Reply 0
Jan 20, 2015 | 02:17 AM
couldn't come up with anyone supplying just the AMG trim piece to replace the AIRBAG 'label' so bought the whole trim from MBenzNL, this write up will be priceless when I tackle the DIY.
Reply 0
Jan 22, 2015 | 02:47 AM
all done!
Relatively simple job with these excellent instructions.
Good value bang for your buck too IMO, wheel should be standard with AMG logo.
Reply 0
Jan 22, 2015 | 06:23 PM
  #32
Yes it is much nicer than the generic AIRBAG trim.
Reply 0
Jun 7, 2015 | 05:10 PM
  #33
Quote: Step 3: You will need to remove the airbag first. To do this you need to release the catch on each side of the steering wheel behind the airbag. First find the dimple on each side of the back part of the wheel (black arrow). Take the flathead screwdriver and push it thru the dimple. You will find that there is a hidden slit within the dimple that allows the screwdriver to enter the steering wheel. Rotate the screwdriver so that the flathead is now horizontal (instead of vertical) and continue to insert the screwdriver into the steering wheel aiming towards the center of the wheel.
Look at the picture below where the airbag has been removed. You need to follow the direction of the BLUE arrows to release the spring clip (Green circle) that is holding the airbag. If you have done this correctly one side of the airbag will pop out (see multiple black arrows in picture below). Repeat on other side. Be careful not to force it. If you bend the spring your airbag may not sit back properly.
I cannot for the life of me get this airbag off. Been pushing very hard with the screwdriver. Does it take a huge amount of force?
Reply 0
Explore
Jun 7, 2015 | 06:09 PM
  #34
No, very little force. The 'catch' for the airbag release is only about 1/4" in. Try sticking a small jewelers flathead screwdriver into the column at a 90deg angle, and make sure the flathead is parallel to the column so you can hit the catch lever. It takes some getting used to, but you don't have to jam it in very far.
Reply 0
Jun 7, 2015 | 07:04 PM
  #35
it'll come, and once you've done one side the second is a cinch.
Reply 0
Sep 14, 2015 | 11:57 AM
  #36
Guys, please tell part number this AMG steering wheel trim.
Reply 0
Sep 16, 2015 | 04:52 AM
  #37
Delete
Reply 0
Sep 30, 2015 | 05:21 PM
  #38
Today I received a AMG steering wheel trim for my C63 507. Looks great! I'm happy!
Part number:
Reply 0
Apr 16, 2016 | 12:20 PM
  #39
Did this procedure today (actually just got the same trim w/ the airbag decal for $30 off Ebay; mine was peeling). One thing I wanted to mention: be careful tightening the Torx screws at the bottom; I didn't have the trim pushed quite into place, and was counting on the screw to pull it in. Instead, the plastic piece with the screw hole broke off. Can't tell by looking, but I'll probably end up replacing it again.
Reply 0
Apr 16, 2016 | 06:02 PM
  #40
Quote: Did this procedure today (actually just got the same trim w/ the airbag decal for $30 off Ebay; mine was peeling). One thing I wanted to mention: be careful tightening the Torx screws at the bottom; I didn't have the trim pushed quite into place, and was counting on the screw to pull it in. Instead, the plastic piece with the screw hole broke off. Can't tell by looking, but I'll probably end up replacing it again.
Do you have a link?
Reply 0
Apr 17, 2016 | 08:31 AM
  #41
Quote: Do you have a link?
Looks like the guy only had the one:
http://www.ebay.com/itm/331821114095
Reply 0
Oct 6, 2016 | 08:21 PM
  #42
Just did this, looks great with AMG logo instead of black airbag logo plate.
Got a great deal from this guy in Latvia, came in 7 days flat for $115 shipped to my door.
http://www.ebay.com/itm/301901064936?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Reply 0
Feb 19, 2017 | 10:43 AM
  #43
Hi,
Great write up, i am interested in doing this to my e class e250 cdi coupe.. i dont like the "airbag" logo, can anyone advise the part number? Or are they all the same for the amg steering wheels?
Reply 0
Jun 6, 2022 | 02:08 PM
  #44
how long did it take for you to do this?
Reply 0
Subscribe
Currently Active Users (1)
