OZ Racing C63 Superturismo scrubbing
MBWORLD MEMBERS
I have just got new wheels on my car and the offset is too aggressive for my guards.
Does anyone advise me to shave the wheel hubs? they are cast OZ racing Superturismo wheels.
The photo I have attached is not its ride height but parked on an angle to show where the trouble is. Currently running stock suspension setup.
Thankyou in advance
Thankyou in advance
Michelin PSS runs wider than other brands.
Can u tell us more infos on the wheels specs (size & offset) & tires size? U might have to run more stretch tires than u have now.
Looks like the tire is stretched on the rim... likely the issue isn't the tire being too wide but the offset is likely too aggressive. I was under the impression, maybe incorrectly, that shaving the wheel to adjust the offset was a very risky proposition from a safety perspective but maybe I'm wrong.
If you have enough room between the caliper and the wheel, you could have a machine shop take off some material on the back of the wheel where it bolts to the car.
This will move the outer edge in away from the fender... Just have to measure how much clearance you have from the wheel to the caliper.
Hi Everybody,
Thanks for all your responses.
Unsure as to the rims offset but i believe its a 9.5 rim and a 255-30-19 Michelin Super Sport tyre.
I am going to make a few phone calls tomorrow regarding getting a little meat taken off the rim hub if anyone is happy to do it or knows anyone in sydney.
From what I've found online, I'd say it's either ET35 or ET40 because these are the available offsets with a 5x112 bolt patter.
That is very aggressive (I like the look) but I can't imagine that You have rubbing issues on stock height.
Before shaving off a few mm off the rim hub, do a research whether it is a safe method for cast wheels.
It will tell you the offset on the inner side of the rim it will say: ETXX look at that the XX number is.
Shaving off from the wheel hub? Really? Cause you didn't plan in advance. Not cool bro.
Too bad the offset is so aggressive at +40mm cuz they look hot!!
Run 235/30/19 in the rear like those VW guys are doing. J/k lol
Good luck sorting out a solution.
If it were me, I would sell the wheels and buy something that fits and chock it up to a good learning experience.
^^ I agree, I don't think it's safe to shave cast wheels.
Like I said, run 235... lol
Hi Everybody,
1 Post
2008 C63 AMG
I had the same problem with those rims. My car is lowered and I used to run 275 on the rear. Had about 8mm shaved of the inside and problem solved. Been running it like that for almost 2 years. There is enough meat on the inside to shave.
2010 Irridium Silver MB C63 AMG Sedan
Love these wheels and think they look killer on the C63. Any new updates. Do you have to shave the inside with stock set up? No other way around it? Not plug and play?
2011 P31 C63 2015 CLA45
I don't even want to understand. But I do love those wheels but am not willing to grind rotors wheel or tires. Just too much trouble. On a side note, you're like a brother to me Zeph. We are a tag team of satire. May the troll be with you.
Yeah the wheels look killer but the whole grinding thing is killing me. I don't want to tear up $4000 wheels like that right away...If they didn't fit I would just end my life and call it a day...
I have also called around and don't even know where to buy them...tirerack was ABSOLUTELY no help even though they sell OZ...
