HK Logic 7 rear speakers
I love the Focals but I'm hesitant to recommend someone spend $750 on a pair of speakers without hearing them in the car myself.
So what model(s) Focals did you use? I'm guessing you did the doors and left the other stuff alone, or no?
I have:
-165 VB - Focal 6.5" Polyglass Components in the front doors and dash.
- PC 100 - Focal 4" in the rear doors.
- Two Kicker 6.75 subs in the rear dash.
- Keenwood Excelon DNX890HD
- 4 ch Clarion amp (plan on replacing later)
Lucky for me, the previous owner changed everything in the Stock-Bose system> removed the HU, rewired amp cables and everything.
It was just a matter of R&R.
Now the system sounds Epiiiiiiiiiiiiic , Pure SQ. No need to wake up the dead.
What he said
Now I have no quarrels with HK or even this system in general, besides the harshness. If I can get that fixed than I'm happy.
Glovebox EQ Mod
Is your music primarily on a media device or do you use one of the car's internal sources?
Bit spendy, but I think I may have a peek around for some for the car in the spring, the stock HK leaves a bit to be desired alright.
It's definitely fixable, it just took me awhile to figure out who the culprits were. In the meantime I stuck a 12v car audio equalizer in the glovebox and ran my IPod through it. That mod cost under $100 and made a huge difference. I'll dig up the post on that mod:
Glovebox EQ Mod
If you want to get a feel for how cutting the harshness of the midrange improves the sound without spending a lot, get the $2.99 AudioForge Equalizer app and experiment with some different EQ curves.
Here's one that would be a good starting point. Unzip it and then email the unzipped file to yourself on the IPhone:
https://mbworld.org/forums/attachmen...unt-s550-b.zip
The C63 has bluetooth and an SD card slot as it is so I just play my music off my iphone connected through bluetooth. I've tried playing music from my iphone through aux and by using an SD card and it's still harsh.
I will look into your post once I'm home.
The AudioForge has a deeper dynamic range for adjustment, and those dots that form the control points can be moved horizontally along the frequency spectrum..left to right = bass to treble. Once you're on a frequency you want to adjust, slide the dot up or down. It gives almost infinite and very precise control...exactly what you need when compensating for specific drivers or sets of drivers like the Alumaprenes.
If you look at that curve in the screen grab, you'll see how far down I had to drag the mids (that bowl in the bottom).
Starting left to right, there's mildly increased bass in general, and then two tight peaks that give the bass guitar, kick drum, tom toms and snare drum their power. In the mids where the backing instruments live...rythym guitar, keys, synths, strings, vocals, all of those have an aspect of high frequency that needs to be attenuated, The trick is not to attenuate it out to the degree the mix sounds dead and flat. You'll find a balance just by sliding the dot around and listening. The peak in the ultra highs is there to add back in some of the highlights and cymbal sounds that may have been lost when the mids were pushed down.
One thing you'll notice right away is that you can get a lot more power out of the stock system than you ever though it had in it, and it'll sound like music again, and not music that's been filtered through a tin can.
Play with it, load that S550EQ preset on to it, and let me know if you get confused about the interface. It took me awhile but I can get it doing whatever I want now.
i tried it and it does make a difference. One thing I noticed was that upon deselecting the "boost" function in the COMAND system for BT Media, it decreases the sound/volume but also the harshness. What I also did was decrease my "volume" when connected playing the music through the car as that also makes the high frequencies less pronounced. Overall the system in the car is quite capable and like you said, you can really AMP it up when it comes to certain ranges of sound/instruments.
the stock Apple equalizer presets are decent as well as i can tell they are working at least lol. What I do notice is that when I'm in the sound options in the COMAND and changing the treble and bass levels, it barely makes any difference. I wonder if it is because I'm not playing it through a CD or if something is amiss. Also do you run with Logic 7 on or off? I find that with Logic 7 on I get more harshness.
I don't have a BT boost function in the S since we don't have BT audio, but anything that adds gain will add brightness with the stock speakers in place. Logic 7 would put the 3.5" center channel dash speaker and the two 3.5" rear surround speakers more into the mix. Those are also Alumaprene and as small as they are they're going to sound really harsh.
If you're unable to get the mids pushed down enough on your app for the volume level you like, the next step is to set up an actual 12v hardware EQ in the glove box between the IPhone headphone output and the car's aux in. It's a mid step between a software EQ and the speaker upgrade, and it does sound really good.
I auditioned the MOD EQ and it serves its purpose as far as being able to knock down sliders 6/7/8/9 to cut the mids, and rolling up 1/2/3 for adding more bottom and power. The sound seems a little more processed and compressed compared to the AudioLogic. I guess that's what $3 gets you
These are what I would have run if I could put 6.5's in the door. Don't let the price fool you...I had a pair of these in another car and they are amazing. Everything the Alumaprene speakers aren't...warm, full, hard hitting, great low end, tight punchy mid-bass, not power-hogs.
http://www.parts-express.com/goldwoo...4-ohm--290-351
Yes, the price is actually $20.72 each when you buy 4.
For the sub, I recommend the Infinity BassLink. If the C has its amp in the trunk like the S, the speaker leads as well as power are right there. I've had this in two w220's and it's great for just reinforcing the very bottom. It has an internal 200 watt amp, one 10' subwoofer and one 10" passive radiator. It accepts speaker-level inputs and has an auto-sensing circuit that powers it off when the stereo is off. The power draw is low enough that you can tap into the car's existing amp power supply...no need to run a cable to the battery.
I think the problem with this setup is that in order to get a much better sound, you'd have to spend more money than normal because it comes with a "decent" setup. I don't think simply replacing the fronts/rears with anything less than a mid/higher end speaker will make it worth doing. Then, you'd have to look at adding aftermarket amps at which you would probably need to add some type of processor to cut over the signal from the headunit to the amps since these cars run fiber in the head units, from what I understand.
I have the H/k in my 15 CLA 250. Sounds good over all for factory. I put lots of time and research into this. Replacing the speakers bad idea they are very high quality. So I’m going with adding Alpine optimum 8 DSP and amp 50x6 and 300x2. This will wake up the H/K speakers and subs in rear deck. If the rear deck are still weak will replace with some Focal 10” subs back there with some custom fiberglass.
this unit integrates flawless with the factor system and the auto tune in DSP gives a great base line to tweak to your ear. Able to adjust with iPhone or laptop is great. With 6 presets can have one for different music types and even valet if so wanted. This is a great options for you all to consider.
