New Release: The Revozport RBS II Styling Kit for Mercedes C63 from GMP Performance
Former Vendor of MBWorld
W211 E500 Estate
There isn’t much you can do to improve the AMG C63, but a range of styling and accessories from Revozport can always allow you to personalize a bit further to suit your own needs. The RBS Styling Kit emphasizes the design cues of the AMG C63 while opening up the possibility for some unique expression.
Following the success of the 2007 C63 RBS kit, Revozport has responded with this RBS II aerokit for the 2012 C63 Coupe/Sedan/Estate. The RBS II design features a more aggressive front twin decked splitter, side skirts with rear bumper flares, the signature rear diffuser with ground effects (this time with an addition of the cooling vents), and last but not least, the trunk spoiler.
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213853&dateline=1361477979)
Front Splitter
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213849&dateline=1361477979)
The RBS II Front Splitter is made by vacuum infusion technology with 3K twill weave carbon fibre. It is designed as a 2pcs combined product to allow better flowing of the air going through the front bumper.
Applicable to all 2012 C63 Coupe, Sedan or Estate.
Mercedes C63 Face Lift RBS II Carbon Front Splitter
Trunk Lips
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213846&dateline=1361477979)
The RBS II trunk spoiler replaces the original AMG spoiler and is designed with a more aggressive angle to create higher downforce.
For C63 Coupe and Sedan
Mercedes C63 Coupe Carbon RBS II Trunk Lip
Mercedes C63 Sedan Carbon RBS II Trunk Lip
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213844&dateline=1361477979)
As the name suggest, it is a small lip spoiler that adds on to the C63 Coupe AMG spoiler. This gives a much more aggressive look and a little different to the usual.
Applicable to C63 Coupe Only
Mercedes C63 Coupe Carbon RBS II Add On Trunk Lip
Rear Diffuser
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213847&dateline=1361477979)
Our signature product for the C63. This rear diffuser is designed for multiple purpose, (Heat Dissipation from the rear differential & High rear downforce). The 3 fins diffuser are more aggressive than the original and goes perfect to the complete RBS II aerokit.
Applicable to C63 Coupe & Sedan Only
Mercedes C63 RBS II Carbon Rear Diffuser With Ground Effect
Side Skirts
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213852&dateline=1361477979)
The RBS II Side Skirt set comes in 4 pieces, 2 underneath the door sills and 2 at the rear bumper echoing the overall design flow of the door sills and through to the rear bumper.
Mercedes C63 Coupe Carbon RBS II Side Skirt Set for Coupe
Mercedes C63 Sedan Face Lift RBS II Carbon Side Skirt Set for Sedan
Mercedes C63 Sedan Face Lift RBS II Side Skirt Set "FRP"
Antenna
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213848&dateline=1361477979)
Mercedes C63 RBS II Carbon Antenna Foil
Air Intake System
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213954&dateline=1361482787)
For the W204 C63 AMG engine. This carbon fiber cooling kit replaces the original plastic trims and provide more cooler and ram air into the intake plenum.
Mercedes C63 Carbon Air Intake System
*Note: RevoZport also mentions a vented lightweight carbon bonnet to go with this kit. We will be sure to keep you updated and put out pictures as soon as we get them!
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213854&dateline=1361477979)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213855&dateline=1361477979)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213856&dateline=1361477979)
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213955&dateline=1361482787)
About Revozport
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=213907&dateline=1361477979)
Revozport Quality Control Management System
At RevoZport, every part, big or small, simple or complex, is specially designed for you. A team of more than 200 dedicated RevoZport employees, including customer support representatives, internal job manager, prototyping, R&D team, material management office, tooling engineers, manufacturing managers, Q/C specialist, finishing technician, packaging engineer, export specialist, and logistic agent, will take care of your product with the highest standards of integrity, excellence, and performance. “Continuous Improvement” is not just our company motto, but also our approach and commitment to better serve you, our valued customer, with the highest quality, but cost-effective products. RevoZport, is intensively learning and following the ISO 9001:2008 quality management standards, which emphasizes involvement and teamwork, evaluating and systematizing processes, reducing quality variations, and defects. By following our own designed "Revozport Quality Manual" which is intensely used within our production facility, the same rule is also set to of our suppliers.
Although RevoZport has its own production facility for composite products, there are still some products or accessories of our products we sub-contract to other manufacturers. To monitor their quality, they are required to follow the Revozport Quality Manual in order to become our supplier. We call it a RevoZport supplier member;
The selection of RevoZport member (enterprise, company, and manufacturer) is based on the manufacturer’s ability to provide quality, price, and delivery. RevoZport selects the company after evaluating its engineering and quality requirements.
The self-audit and survey reveals the procedure of a formal quality survey and classifies the quality potential and rating of the candidate.
The receiving inspection shows the quality inspection responsibility and procedural criteria.
The prototyping / mock up sample plan establishes guidelines for techniques and inspection methods utilized for incoming product.
Our QC team, on a continual basis, monitors the quality rating. Performance and classification are related as a percentage.
Communication in formal response and corrective action must take place for material defects.
The method of evaluation is the certification process and establishes certification procedure for future production shipments.
The selected member will decide all purchased material after the candidate sufficiently meets the previous history quality and production requirements in similar supplied products and satisfies an on-site quality survey conducted by a RevoZport audit team.
Front Splitter
Trunk Lips
Rear Diffuser
Side Skirts
Antenna
Air Intake System
About Revozport
I still have not seen one good pic from the side angle to really see what this spoiler looks like.
Revozport needs to take better pics of the trunk spoiler on the sedan...
I am talking about this angle (boca spoiler):
![](http://img.photobucket.com/albums/v382/Roswell88/2010%20C63%20AMG/IMG_0372.jpg)
W211 E500 Estate
Do you have any other pics of the RBS II Trunk Spoiler for the sedan?
I will see what I can find but its very similar to the Gen 1 sedan spoiler. I mean very similar
W211 E500 Estate
All the pricing is on our website by clicking the links @ each product picture. I will be glad to work on a group buy pricing structure if there is enough interest.
W211 E500 Estate
I'm about to leave the office for the day so any other questions please feel free to email me otherwise I will respond in this thread on Monday.
Have a good weekend everyone!
W211 E500 Estate
https://mbworld.org/forums/c63-amg-w...-lot-more.html
Here you go. Below is a link to a stage 2 RBS Kit we completed a few years ago.
You are a GOD amongst men.
Thought I would see Sasquatch before ever seeing this many angles of a Revozport spoiler in the wild!
I think this is the best spoiler for the C63...
Thank you very much.
I need a few more days of final contemplation before placing an order.
W211 E500 Estate
