This doesn't sound good
Former Vendor of MBWorld
The things is the car is under warranty. So it's best to just let the dealer take of the problem. I posted this more for documentation in case others run into the same problem.
2012 C63; 2011 E350 Coupe
On my 2010 C63 with 17,880 miles on it. I started it up and heard this. Just posting so there is an online record of it and others can compare their sound to mine. My car is 100% stock.
http://www.youtube.com/watch?v=HT9QG...ature=youtu.be
#32
AMG & RR
Same sounds my car is making. Dealer can't reproduce of course. In my case it comes and goes but is there 90% of the time on a cold start and returns randomly throughout the day. See if the ticking/clicking noise increases as you increase the RPM and let me know. Thx!
#35
I got my car back because the dealer could not duplicate the sound. The sound goes away after the car is warmed up. To me it sounds like a lifter bleeding down. Once the car is up to temp problem is gone. It only happened that one time.
IF it happens again. I will shoot a video again. and have the car towed to the dealer. This way they can pull the valve cover off and check to see what exactly is going on. While the lifter is stuck. I'd advise others to do the same. If you hear it. Just turn the car off and get it towed. Bring it in cold, dont give your engine a chance to fix the problem. Once it fixes itself you will never know what one was doing it. So basically the dealer has to catch it in the act.
#36
#38
Here we go again
Today I was getting ready to leave. I started the car up and the sound was back. Rather than drive the car (Driving seems to fix the problem and the sound goes away). I called road side for a tow. 2 hours later the flat bed shows up and took the car and myself to the dealer.
This time I'm pretty sure they were able to hear the racket coming from the valves area. I got a text from my friend who is the service manager at the dealership. I was told they are removing the valve covers first thing in the morning and they should know more once they see whats going on.
Here is the video from this morning.
#40
C63 & Mustang Mach1(s)
Bump. MBH what was the result?
I started her up this morning and had the "lifter noise" really loud for the first time 22k miles almost out of warranty, July. Paranoia is setting in
#41
I heard a brand new SLS sitting on the dealer's lot ticking away two weeks ago. I asked them if there was a discount for the new car that needs engine work and they just laughed.
#42
My issue is fixed and has been trouble free since. They replaced 6 lifters or something like that.
#43
Make sure you video the sound. Or when it is doing it also just have it towed to the dealer. The problem may fix itself if you drive. Thats what you DONT want. You want the dealer to hear it. So when it does it just get it towed.
#44
07 E63 + 07 CLK63CAB
MBH Motorsports,
Good to hear you are problem free now but can you tell us actually how many miles did you have on the oil change ( 0-40 Mobil) or (5w-40 Mobil) the first time of the tick issue. Did the car sit or has it sat for long periods of time, like weeks or months.
Thanks in Advance
Thanks in Advance
