Need some Help with CEL.
I got the famous Bank1 lean code. p0171 I have replaced the purge valve and the oxygen sensor. Of course I am still getting the same code. I have performed a smoke test and everything looked to be good and sealed. When I purchased my car, one of the first maintenance things I did was the K&N filter. When I was changing them I already noticed that my charcoals were gone (most likely by previous owner) I am tuned and have been for couple thousand of miles and never thad this code come back during or after the tune.
What's my next best step, trying to replace the Intake Manifold Gasket? Mass Air Flow Sensor? I'm getting a little tired of replacing pointless parts that are perfectly good. I am not planning on going to the dealer, so I am trying to find the actual resolution.
09 C63 around 45k+ miles.
Thank You For all help.
Your best bet is to go back to stock paper filters and charcoals in to be rid of the CEL.
Unless someone can recommend a better option to go about...
