C63 AMG (W204) 2008 - 2015
Anybody adjusting Camber to make tires sit flat?
Old Apr 25, 2013 | 04:31 PM
skaarlaj's Avatar
ford svt's, and C63!!!
Just like the title asks, my car rides on the insides of both rear tires, and I'm wanting "straight-line" traction.
Old Apr 26, 2013 | 01:16 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
I haven't tried it on the C63, but we used to run zero rear camber on my formula race cars when I was racing. Probably depends on the car and how you drive it. You'd probably have to play with the camber and test it. For the street, it would probably be fine at zero.
Old Apr 26, 2013 | 10:01 AM
adv4nced53's Avatar
2010 C63 AMG
Zero camber is for cars with no suspension travel...like a formula race car haha. The camber is there, so when you lean into a corner, the tire gets maximum grip. If you run 0 camber normally, you'll have positive camber while cornering hard, which isn't a good idea.
If you want more traction, take some air out of the tires or get stickier tires. I doubt drag racing is the only thing you use this car for.
Old Apr 26, 2013 | 11:00 AM
skaarlaj's Avatar
I just put on some Nitto 555r's last night and they helped a lot, but at the end of the day, the tire's contact patch isn't sitting perpendicular to the road. I don't want it to corner terribly, just thought about reducing the negative camber so it at least doesn't sit like a lowered Civic!! I think when it's extreme enough you can quickly see it with the naked eye, it can't be good for tire wear either?
Old Apr 27, 2013 | 01:14 AM
DuaneC63's Avatar
AMG GLC63. Audi R8
There is no factory camber adjustment on the front or rear. For the front you need camber (crash) bolts. Any good alignment shop will have these. For the rear you need adjustable rear control arms. ACG in San Diego has them. Ask for Sean. In any event you don't want to run zero camber. The car won't handle.
Old Apr 27, 2013 | 08:40 AM
4ramin's Avatar
AMG GTR, GTBS,944 Turbo, GT4RS,GT2RS,GT3rs,GT4,Lotus Exige S,BMW M3CS,M4CSL,Lamborghini STO, Tesla Y
I have , get a set of k-Mac bushings, I have the front and rear camber and front caster. Since I don't drive the car much and hard cornering is important to me I've put about 2 degree negative camber in both front and rear. This is done to keep the tires flat in hard turns... Call Kevin at k-Mac as he's a great guy to deal with.
