C63 AMG (W204) 2008 - 2015
Just put on exhaust, car feels weird sometimes when I hit the gas.
Old May 6, 2013 | 01:31 AM
tomespo's Avatar
Huracan STO
Seems like it happens mostly in C mode. When I go to hit the gas it feels like its in too high of a gear and then goes and downshifts. I put on the exhaust today and I feel like it made it worse, feels like the car jerks. Anyone have any input or am I just going crazy lol.
Old May 6, 2013 | 01:44 AM
LAMB09's Avatar
2011 C63 AMG
FYI if you can provide more details like what exhaust mods you did and if you have a tune or not or any other performance mods will help others chime in with their thoughts.
Old May 6, 2013 | 02:20 AM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
ECU hasn't adjusted? Maybe you need a tune or reflash?
Old May 6, 2013 | 02:37 PM
tomespo's Avatar
Huracan STO
I was thinking ECU . It is a fluid motor union exhaust system deletes all cats and adds a resonator. Going to get tuned soon
Old May 6, 2013 | 02:48 PM
Try the method to reset your TCU...maybe that'll help?
Old May 6, 2013 | 05:26 PM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
Well "C" mode starts off in 2nd gear i believe . Does it do it in "S"?
I always drove in "M"
Old May 7, 2013 | 12:04 AM
tomespo's Avatar
Huracan STO
I'm sure it's nothing crazy as the car only has 400 miles. What is the break in period for these cars? Also how do I reset the tcu?
Old May 7, 2013 | 09:32 AM
Believe break in is 1000-1200 miles. Many argue about break in procedure, I personally drove my car like it was already broken in right out of the lot with 5 miles on it, and tuned it with about 1500. Only problem I ever had was Purge Valve, but that was a common issue on the earlier ones.
Don't think it was ever confirmed if they ECU/TCU reset trick worked on the newer cars.
1. Turn the igniiton key to the "on" position which is just before you crank the engine to start.
2. Press the accelerator to the floor and hold for 5 seconds.
3. Then turn the key to the off position but do not remove the key, then release the accelerator.
4. Wait at least 2 minutes, the ECU is then reset.
5. ECU is now reset and you are ready to get new rear tyres.
The ECU rest procedure only erases the adaptive transmission and throttle settings. It does not erase any of the fuel, timing or other programming.
Old May 7, 2013 | 12:43 PM
natman316's Avatar
2012 C63 2015 C300 sport
I think you will need to be tuned to run completely catless. so that should solve your problems
Old May 7, 2013 | 12:46 PM
Ekort's Avatar
Veteran: Navy
C63
+1
Old May 11, 2013 | 02:16 PM
SROC276's Avatar
2010 C63 P31 AMG
Unhook battery and let it sit for about 15 minutes. Should reset your ecu and Tcm. Worked for me to remove thE jolts from tranny and better than doing Tcm reset alternative which I tried for weeks to reset. Adaptation is 1-2kmiles agreed.
Old May 11, 2013 | 02:35 PM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Just like above....YOU NEED A TUNE with that set up.
Old May 11, 2013 | 07:52 PM
khmergod's Avatar
2011 P31 C63 2015 CLA45
Any exhaust work should get custom tune. Most people ran their cars like they stole it on day 1. Pulling strong!
Old May 13, 2013 | 08:53 AM
I am Jeff's Avatar
Steel Grey Metallic C63!!
I usually go for a drive in Mexico and do a few 5-150+ runs. The ECU adapts itself from granny mode.
