C63 AMG (W204) 2008 - 2015
Wheel compatibility question
Old May 31, 2013 | 12:35 AM
kanyeeast's Avatar
2009 AMG C63
Does anyone have any fit problems with aftermarket wheels due to the high offset of the stock wheel? (54mm). I wanted to go with a 19x9.5 rear with a 28mm offset and 19x8.5 with 25 mm offset in front. You may recognize that as the wheels from a 2011 cls63. Anyway it seems that the wheels might be too wide on the outside so...
Will these fit?
If so, will they look bad because the wheels are sticking out the side?
link: http://www.allfactorywheels.com/prod...ear-85067.html
Old May 31, 2013 | 09:31 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
No go, these offsets are too low. It will stick out & u will have major rubbing problems.
