CEL rant
You should see biglee73's photos. He has barely enough clearance with stock suspension to get in and out of his driveway.
Fingers crossed.
I turns out the "leak" may actually just be a seal issue between the headers collector and the straight-pipe exhaust. It looks like my exhaust tips on the driver's side extend further out and one of the braces that holes the two tips together is bent, most likely due to some impact that may have pulled the collector off of the headers a bit, enough to break the friction seal.
An exhaust/muffler shop is looking at it right now and thinks it can just be adjusted. Fingers still crossed. Not sure how this would have happened because I couldn't see any obvious sign of impact, but with a lowered car, it could have occurred anywhere at anytime.
Everything at the exhaust shop was tightened up and refitted properly, CEL cleared, and fog light fixed. I am mostly relieved it didn't end up being a crack in the headers collector and that I didn't have to drop the whole system. Fingers are still crossed for the next 50 miles or so to make sure it's really gone...then I can reschedule my dyno
Thanks, everyone, for putting up with my drama.
