Group Buy! Eurocharged handheld and tune $850 shipped!
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
Hey Everyone, its time for a new sale! We are going to do a group buy for the units! The price is only for new purchases and requires all 10 customers to pay for the package. We are getting a discount from our supplier so we are passing that savings to you!
We are offering our handheld flasher with our performance engine software for only $850 shipped in the US! (10 people required) No need to send in your ecu and you can flash the car from the comfort of your garage!
![](http://www.eurocharged.com/images/Euro_mygenius1.jpg)
You can order here!
Price difference will be refunded once we hit that 10 mark.
This includes up to 2 tunes at no additional charge! We can create a Race gas tune, nitrous tune, catless tune, custom dyno tune, US 91, US 93, EU 95, EU 98, etc.
The flashing process takes about 80 seconds to complete.
There is a full recovery mode built in to the programmer as well!
Dyno result in SHOOTOUT MODE
![](http://www.eurocharged.com/graphs/c63/Eurocharged_C63_Stock_Tuned_Dyno.jpg)
Larger Graph
Handheld Flasher FAQ:
Do I need a PC to use the handheld:
The software only works on a mac if it can run windows as well.
You can also use any pc to set it up the first time. After that, no pc will be needed
Can I use this device if I have another vendors tune?
Yes but with a caveat. You would need to send your ecu to Eurocharged houston to be backed up to our file structure to be read by the handheld. You could then switch between stock and tuned, but your tuner couldn't write more files for the device.
Is the tune detectable by the dealer?
If the tune is left on the ECU then there is a chance the dealer could find it if they really wanted to. However, the handheld programmer will allow you to flash the car back to stock. Once this is done it is 100% undetectable as our programming doesn't trigger a full write, so the flash counters don't move!
How many tuning files can I keep on the device?
We supply you with 2 with your purchase, and you can purchase more if needed. Some of our bmw customers have over 10 files on the handheld at a time. The device can hold many tunes (more than needed). You use the supplied software and connect the device to your PC via a USB cable to manage the device. You can add / remove any tune you like. However, the stock software cannot be removed.
Can I use the handheld with more than one car?
No, the handheld is vin locked to the vehicle
How do I get a stock file for my car to go to the dealer with?
Generally you would read the stock file, send it to Eurocharged, we will modify it and send it back. However, the 63 ECU cannot be read via OBDII so the device will only ID the car. Once you have this ID file, you send it to us. We will then match your stock software based on the ID file, attach it to an email and send it on the way to you. From that point forward, you load all tunes via the same method.
To sum it up, the device will arrive blank. We will send all files via email for you to load / manage.
Is there a way to "unmarry" the unit from the car/vin/ECU, so it can be used by someone else?
yes, but you would need to send it into Eurocharged Houston to get reprogrammed. There is a $200 fee for this service
Can I apply retunes with the purchase of this device?
Yes, this just makes it easier as we can now just send you a file for you to flash as your convenience
Would it possible to have a tune for valet?? So they can't go over 10mph in our car.
Yes, that is not a problem
Also, will this programmer work on W211 E63, W212 E63, C219 CLS63, CLK63 BS or is it only designed for the C63 ?
This programmer also works with C300, all 350, all 550, all 63 N/A cars!
How long does it take to flash a tune?
Depends on the car but typically around 80 seconds
What happens if I unplug it when its writing? Will I destroy my ecu?
The programmer has a recovery mode that will fix any issues encountered during the flash. We pulled the programmer from the OBDII port on our CLK63 BS and the recovery mode fixed it without any issue.
How Many times Can I flash the car without damaging the ecu?
The memory inside the ECU can be programmed more times then you will be able to accomplish. In fact, the data inside the ECU changes every single time the vehicle is started.
Does this device work on non US market C63 as well?
The programmer works on all 63's, no matter the market.
You can order here!
Larger Graph
KTM 200 xcw
Jake, if we opted to add the TCU tune on the handheld as well, what would the additional charge be??
Just out of curiosity b/c nobody seems to have this as an option.
I'd almost rather the TCU tune over the ECU tune, the trans tune I'm sure will feel better on the butt than the ECU tune, it's more of a noticeable change. I hate the shift patterns of the stock tune, it just doesn't seem "fun" to use the manual mode or the paddle shifters in any mode.
i'm assuming the OP is eurocharged even though his handle says loungn14?
also, no disrespect, just some (lazy style) due diligence ... can anyone share their personal experiences with eurocharged tunes? good and bad!
When u say the handheld comes with 2 tunes, does it means we can only flash it back to stock 2 times.. Or it means u got 2 types of tunes (i.e V3 & V4), and we can switch them around as much as we want?
SPONSOR
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
https://mbworld.org/forums/c63-amg-w...ed-canada.html
https://mbworld.org/forums/c63-amg-w...ne-review.html
http://www.eurocharged.com/blog/297-ecreviewec63canada
http://www.eurocharged.com/customer-testimonials?id=132
https://mbworld.org/forums/c63-amg-w...rocharged.html
KTM 200 xcw
SPONSOR
How much more power would a 98 vs 93 octane tune make? I have the V4 tune already. Just wondering. Thanks!
im having a hard time finding this on your website. would you mind posting up a link or PMing me? i saw the "handheld" and the tuning software, but im not sure these are what the group buy is for.
thx
SPONSOR
SPONSOR
Our performance tune comes with and a choice of another. All tunes are based on your current mods, elevation, and octane of your gas in your area.
Im most likely in. Like the idea of a flashloader as ive had tunes with units like this for previous cars. Will decide this weekend. Also, on a sidenote, this TCU tune spoken of above....will make shifts faster I understand but does it also make the shift occurence more immediate following the actual shift via paddle, as in lessen the responce time? The tcu cannot be done via sending you our ecu? Im new to this platform so I dont know all of the tunes and features quite yet, thank you.
Does the catless tune allow the monitors to set for those of us who have to have this in order to pass state inspections?
Wow. I ordered mine today before reading this and EC honored their group buy for me. Thanks guys! This is a fantastic value.
