C63 AMG (W204) 2008 - 2015
Facelift LED lights... how to run as DRL?
Old 01-31-2021, 03:41 PM
  #51
jaimejrivera's Avatar
2012 C63
Originally Posted by AnkitSimkhada
Can anyone help with this??
I had the same problem with the flickering and ended up connecting a wire from the fuse box to the jumper. I placed a diode also to prevent power from the lights reaching the fuse box. This way the DRL dont dim at night.
Old 01-31-2021, 04:31 PM
  #52
AnkitSimkhada's Avatar
w204 C180
How did you connect the diode?
Hi mate,
Thanks for your quick reply!
I’ve got a few questions if you don’t mind!
did you connect the diode to both sides? And which diode did you use?
By the jumper do you mean the wire you used to connect the drl and c-led?? How did you connect all three to the fuse?
Sorry for all the questions, I’m new to all this!
thanks
Old 01-31-2021, 08:20 PM
  #53
C63AMGeez's Avatar
W204 C63
I’ve been really wanting to do this but knowing an error message pops up is a turn off. Would love to get it programmed instead if anyone willing to do it remotely.
Quick Reply: Facelift LED lights... how to run as DRL?
