C63 AMG (W204) 2008 - 2015
Tip For Ebrake Clicking Fix
Old Jul 26, 2013 | 11:33 AM
khmergod's Avatar
2011 P31 C63 2015 CLA45
So I was running fine with 10mm spacers and 40mm extended bolts for 120 miles until this morning. Mercedes rear ebrake is known to have a small clearance of ~2mm. I'm at that point.
This morning I heard some clicking while accelerating and freaked out, and thought it was my engine. Clicking was faster the faster I went. Rolled windows down and concurred that it was from the rears. This has never happened before.
I only drove about a mile total since it started and am hoping I didn't damage anything.
Here's what I did to make it go away. I pulled on the parking brake release for the hell of it and it was still clicking. I drove for a little bit but no avail. I was about to give up and remove spacers and use regular 28mm bolts, but then something popped in my head.
I depressed the ebrake all the way down then pulled the release. It worked like magic. I conclude that my clearance at the moment is less than 1mm and the parking brake probably got stuck after 5 days of sitting. To ROSWELL: Have you had this happen to you?
Tip for anyone else getting extended bolts. Make sure they don't exceed 2mm from OEM. I recommend finding exact bolt sizes if possible. If not shave them to specified length to avoid any headache.
