Dallas Raceway 8-9-2013
#51
Nice... do they come with hub centric rings to fit or are you getting those
separately?
separately?
hey jumpinjim... you said there was a c63 with LTs and eurocharged tune
locally... who is it? not many that i know of in dallas with this set up... we
should have a small meet and drink of our own.
https://mbworld.org/forums/c63-amg-w...g-24-meet.html
#52
hey jumpinjim... you said there was a c63 with LTs and eurocharged tune locally... who is it? not many that i know of in dallas with this set up... we should have a small meet and drink of our own.
i checked the DA on 8-10-2013 when you guys went... it was about 2700. that's pretty high.
the highest DA i ran in was 2389 in november 2011. i was running low 12.2s @ 116mph on street tires. and that was when i was still learning how to launch properly.
#53
I don't know if hub centric rings are required. Are they? I just got them picked up today. I haven't tried to mount yet.
What are LT's and if you guys want to meet up sometime sounds cool. I have a car club I started a couple weeks ago. Carrollton Motor Club. We could meet this weekend at that.
LTs would be your headers. Sounds like a fun club. We'll have to stop by sometime, if I can shake this flu.
#54
our cars bore size is 66.56mm... and the wheels you got i believe are 72mm... so it's bigger... they usually make it bigger so the same wheels can fit a variety of cars with different bore sizes...
if you mount those wheels to your car... then the weight of your car will be all on the lugs instead of the hub... (i'm sorry if i'm not using the correct terminology... i'm going off memory from what i've read)
so to make it hub centric, some wheel companies provide the correct hub centric rings for your cars fitment, or you need to find some elsewhere... perhaps a wheel shop or maybe even discount tire... this way it'll make that 72mm into a 66.56mm and you can mount the wheels... so it should be a nice snug fit and should reduce the possibility of vibrations and such...
LT are longtube headers... from your sig it says you have kleeman headers... i thought they only made shorties but i guess they have LTs now... which do you have? and do you have stock cats, high flow cats, or catless?
and in regards to the meet, i work on saturdays so i wouldn't be able to make it... however, i was planning to go to the meet at the enkei warehouse that same day... supposed to go until 7pm.
#56
DA takes into account the temp along with other things such as humidity... so i think going by DA would be safer... if the temp is the same and the humidity is higher, then usually the DA is higher...
#57
The one thing DA doesn't take into account though is if your particular car is heatsoaked or not. We think that's what's going on. Some more examples would be good though. We'll be out at the track in a few weeks after I get my tune done and I'm no longer dying. Bring your car and jrsjr65 will probably have his out with the new drag radials to try out along with fly 2 nite. Should be a little cooler than last time and we'll see how they all run.
#58
So if you have 2 otherwise identical cars, but one has a better cooling setup than the other and you run them at the same time its likely the one with the better cooling will be faster. Not because the cooling adds power, but because it prevents power loss due to heat. The 6.2 doesn't have an intercooling system so its more at the mercy to heat than would a different car. That's why you see people putting ice packs on even NA cars at the dragstrip to try to mitigate the heat. Also things like meth injection. All to control heat and prevent power loss. That's why you always hear about the 55k guys complaining about broken intercooler pumps. Although the DA and heat would be the same if you're running with a broken ic pump it becomes considerably slower as it becomes heat soaked as it cant cool the air and the ecu pulls timing to protect the engine. Make sense?
#59
from my experience and some others. The c63 seems to get stronger when hot lapped. I've never iced my car but i've hot lapped it many times. Back to back to back runs and it gets a little faster. Probably adapting to the car being run harder than normal.
#61
My old e63 and current c63 both get faster with hot lapping. I attribute 100% of this to reduced IATs as I'm a traction master
just ask JumpinJim and his SL. Don't ask the M5 it lies constantly about everything. Also it's so hot my c63 won't lose traction on a prepped track so that could only leave the IATs.
#62
I got the DR's today. Still in my truck. Thanks for the info guys. I have Kleemann LT headers, ceramic coated, black.
Reading posts bring a couple questions. Is an OEM or aftermarket intercooler upgrade Available? That or any cooling system improvements available? Water meth? Can that be used on an NA engine? I used it on diesel TT truck, basic, efficient operation.
#65
JJ - What is an average baseline for your car? Those numbers seem pretty impressive to me! cant wait to see what Kleemann tune does for you.
bluejae the DR's are here if you want to check them out. Like I said not sure where everyone lives but everyone welcome to meet up this Sat at car show I have set up... Just got the 62 T-bird in today, I need to flip it so I can buy a Weistec SC!
#67
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
have you heard anything about whether you need hub centric rings or not? i did some more reading and some places are saying that the thing about the weight on the lugs are not true. that the force is actually somewhere else. so it's just the matter of getting them centered on the hub during the install.
i'm not sure about our lug nuts but if they are tapered, then a hub centric ring may not be needed since the lug nuts will self center itself while tightening...
edit: tapered
EDIT AGAIN: i think the c63 uses lug nuts not lug bolts. and they are ball seat.
#69
In addition to what bluejae said about lug bolts, make sure you use the right ones. MB uses ball seat lug bolts, but most aftermarket wheels use cone seat bolts. Don't use ball seat on them if so or you could damage the wheels or worse. Discount tire should have told you what bolts are needed for the TSW wheels and got you the bolts if they need cone seat.
#70
The lugs (cone or ball seat) will not center the wheels perfectly without hub centric rings and you will likely experience vibrations at 75 mph and higher. You might get lucky and get them centered perfectly but there is no guarantee. You might not notice it or it might not bother you at the track for rear wheels but on the street and on front wheels it will bother you if you don't get them perfectly centered.
#71
i've been doing some research on finding the parts i'll need. but i didn't think about possibly needed different lug nuts/bolts. damn, more things to find. it's been a really really long time since i've gotten aftermarket wheels for a car... i had no idea you needed to take all this into account.
- wheels with correct offsets
- tires
- hub centric rings
- lug nuts (i believe the c63 uses lug nuts and not lug bolts.)
- tires
- hub centric rings
#72
I haven't had time to dive into this yet on the lug nuts. I am going to take the car back up to the same Discount Tire and get all this checked out with them.
