Weird bolt/screw when doing diffuser swap?
2013 C63 AMG
I was following the DIY for installing a new rear diffuser, and immediately ran into a road block. Where it said there should be a T20 torx head bolt on the sides by the exhaust was instead a weird little bolt that looks like you'd need a Y shaped bit to undo. I went to HomeDepot to see if they had anything and the guy had no clue where I could find a tool for this.
2013 C63 AMG
I'd just gently drill the rivet out. even if the plastic around it melts a bit, you can always use washers if you ever plan to reuse it.
