C63 AMG (W204) 2008 - 2015
help me verify rim fitment and tires?
Old Sep 30, 2013 | 08:38 PM
gsanders's Avatar
CL55
Hey gang,
I have a 2013 C63 coupe with Perf package. I would like to buy Merc OEM rims that are:
Front: 19" x 8.5", 5 Lug, 5 Triple Spoke, 30mm offset.
Rear: 19" x 9.5", 5 Lugs, 5 Triple Spoke, 31mm Offset.
I know the offsets are not right but can I use spacers?
I wanted to do 245/35f & 275/30r tires.
I know there are other posts about this but I just wanted to make sure before I pulled the trigger.
Thanks all!!!!!!
Old Sep 30, 2013 | 08:39 PM
noodleman's Avatar
2014 E63S Wagon
there's no way you can make those fit. spacers only push the wheels out more.
Old Sep 30, 2013 | 09:14 PM
Vise_'s Avatar
2013 C63 AMG, 2013 B250
Yeah not a chance. Your best bet is to do some research on the forum for sizing/fitments that are proven to work fine on the C63.
Old Oct 1, 2013 | 12:11 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
U need at least +38mm front & +50 rear with these wheels width, so adding spacers will only make ur offset lower.
Spacers will be good to clear the brakes or inner suspension but very bad for rubbing the fenders as they will push the wheels out even more (like noodleman stated).
Old Oct 1, 2013 | 03:32 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Let me know if there are any aftermarket wheels I can help you with, I would be more then happy to get your C63 sitting on some nice wheels!
-Arsha
Old Oct 1, 2013 | 09:26 PM
gsanders's Avatar
CL55
How about these rims?
Front Size 19X8.5
Offset +45
Rear Size 19X9.5
Offset ET +45
Bolt Pattern 5x112
Hub Bore 66.6
Old Oct 2, 2013 | 12:05 AM
Roswell's Avatar
The front will be fine although not flush.. U would need +38-40 mm to bring the wheels closer to the fenders.
The rear are still agressive though at +45mm. It will work if u stretch a 255/30/19 on them or else u will have to stay at stock height if u want to avoid rubbing.
Old Oct 2, 2013 | 11:26 AM
gsanders's Avatar
CL55
Perfect Fitment for 19" Rims
As all of you can tell, I am a newbie
If I want perfect fit and I am going to put 245/35 in the front and 275/30 in the rear, what is the proper offset when I am looking at rims? Is there anything else I should look for when looking at rims besides offset?
Thanks to all for helping!!!!
Old Oct 2, 2013 | 02:04 PM
Roswell's Avatar
19x8.5 +40 f
19x9.5 +50 r or 19x10 +53r
245/35f & 275/30r should be flush & no rubbing
Old Oct 2, 2013 | 02:43 PM
gsanders's Avatar
CL55
Really appreciate your help!!!! Will post pics after I get the rims.
Old Oct 2, 2013 | 02:44 PM
CarHopper's Avatar
E63S | X5
Also depends on what your idea of a perfect fit is. Scroll through the wheel thread that is a sticky above, post some of the pictures here and I'm sure the members will chime in on the sizes of those wheels
