MBH headers installation tips?? C63BS
Would be great to get advice from people that have already done the install on how to best proceed with it. I was told that the engine needs to be freed from its mounts to allow for the headers to slip into the tight area.
Would be great to get good insight with regards to the install (what on the car needs to come off etc)..it would also help others that are looking at getting/installing these headers.
thanks
thanks
Also needed to remove the brace in the middle of the car, easily done and I don't know if there's a way to replace it or if there's some other solution for it. I've tried contacting MBH about it but can't get an answer.
Overall it wasn't a bad header installation, I thought it would be worse but it's about the same as I've delt with in other modern cars - though I will say every modern car I work on lately makes me appreciate how user friendly my Trans Am WS6 is lol
Ratchet wrenches, extensions, etc. all needed, 11mm I believe?
Removing the stock manifolds is the hardest part. Installing the headers is easier since you have more room around the bolts.
Ive done it three time now, its a pain in the *** evertime.
Amen!
I wish I didn’t have these huge hands, since getting to those 5 nuts which are 11mm from the top, is a MAJOR P.I.T.A. in my W211.
I’m doing my install at the moment and taking my time with a tall jack and 4 jack stands.
