Door lock problem
C63 black series
Door lock problem
I have a 2013 c63 BS which i just bought second hand with 2400 miles.
Car is in perfect condition, like brand new.
My passenger door cannot be open from outside when
car is unlocked. I have to manually press the "lock"button from drivers door to make passenger side unlock...its the reverse of what i should do. Then once door is closed, it locks up again automatically. Key fob will not unlock it either.
Any advice from anyone with or has had this problem???
You're not going to be thrilled with my answer but . . . take it to the dealer. Good luck.
Pretty sure it has something to do with the security setting applied to the key ie there is a setting whereby only the drivers door unlocks using the key or using the door handle if you have Keyless Go option.
In a 2010 model you can reset it to unlock driver and passenger door by pressing and holding the lock and unlock buttons on the key for about 5 secs or so until the battery check light flashes twice
